Do you leakdown at BDC or TDC
Old Jul 12, 2003 | 07:45 PM
Slalom4me's Avatar
Slalom4me
Default Do you leakdown at BDC or TDC
Anyone go to the trouble to hold the piston at TDC instead of
letting air pressure push it down to BDC while performing leakdowns?
If you DO do it at TDC, are you holding the crank at the flywheel
by dropping the cover or is there a better way ?
[Modified by Slalom4me, 8:38 PM 7/12/2003]
Old Jul 12, 2003 | 09:06 PM
oldace84's Avatar
oldace84
St. Jude Donor '04 & '05
Default Re: Do you leakdown at BDC or TDC (Slalom4me)
Thats one hell of a good question.......damn you got me......
someone help us!!!!!!!!!!!!!!!!!!!!!!!!!!!
tony
:smash: :smash: :smash: :smash: :smash:
Old Jul 12, 2003 | 10:14 PM
Stingray1970's Avatar
Stingray1970
Most leakdown tests are done at TDC. The cylinders wear in a taper due to the piston side thrust on the power stroke. Hence, the top of the cylinder will be larger than the bottom. You would be more likely to show more leakage at the top and thats where the power loss would be if the rings were sealing poorly. :crazy:
Old Jul 12, 2003 | 10:37 PM
Lionsden's Avatar
Lionsden
If you're at true TDC air pressure won't push the piston down. If your off TDC the crank will want to rotate.
Dan
[Modified by Dan Plett, 9:39 PM 7/12/2003]
Old Jul 12, 2003 | 11:41 PM
Slalom4me's Avatar
Slalom4me
Default Re: Do you leakdown at BDC or TDC (Dan Plett)
If you're off TDC the crank will want to rotate.
Well, that makes perfect sense. But you are gonna laugh at what
comes next.
Apparently, I did not have the piston at 'true' TDC the first time I
did a leakdown (it was a while ago) and you know what happened.
I immediately resolved that I'd never be surprised again and built
a fixture that holds the crank via the ring gear.
I've never given this approach a second thought until someone
questioned why I go to the extra effort. When I responded by asking
how he does it, the answer was 'at BDC, of course'. Well aware of
how cylinders wear in a taper, I pointed out the flaw in his method.
He's an older gent and someone whose opinons I generally respect
but I inherently knew that on this account, he had to be mistaken.
Funny how the obvious eludes our notice sometimes.
Excuse me now, I gotta go try a leakdown just to prove that the
fixture is not required.
Old Jul 13, 2003 | 12:52 AM
jfb's Avatar
jfb
In any part of the cycle, one or both valves are open at BDC, so a leakdown at BDC is not possible.
To Do you leakdown at BDC or TDC
