1988 Transmission Problem
Old Jul 12, 2003 | 10:07 PM
jaa1992's Avatar
jaa1992
From: Life is just one big track event. Everything before and after is prep and warm-up and cool-down laps
Cruise-In III Veteran
Cruise-In IV Veteran
St. Jude Donor '12
Default 1988 Transmission Problem
Does anyone have any ideas?
It does not hold in Park
It does shift normally when driven.
Something simple?
or
Something bad?
Old Jul 12, 2003 | 11:58 PM
oldace84's Avatar
oldace84
St. Jude Donor '04 & '05
Default Re: 1988 Transmission Problem (jaa1988)
A 700R4....shifter needs adjusting..At least thats what I feel.....
Hope this helps you....
tony
:smash: :smash: :smash:
Old Jul 13, 2003 | 08:54 AM
jaa1992's Avatar
jaa1992
St. Jude Donor '12
Default Re: 1988 Transmission Problem (oldace84)
Well that sounds simple.
ANyone else have ideas?
Old Jul 13, 2003 | 10:40 PM
Rick86's Avatar
Rick86
Do you mean the car will roll when in park? It could just be linkage, but there is a parking pawl that engages into a cog that locks the transmission so it will no roll. I always make sure I set the parking brake (notice I didn't call it an emergency brake). By setting the parking brake when you still have pressure on the brake pedal the weight of the car is not being supported by the parking pawl.
Old Jul 14, 2003 | 09:30 AM
jaa1992's Avatar
jaa1992
St. Jude Donor '12
Default Re: 1988 Transmission Problem (Rick86)
Yep, thats exactly the symptom. Using the parking brake is a good idea except that since the problem started I've had to rescue my wife twice because she thought the parking brake was broken :eek:
Old Jul 15, 2003 | 03:40 PM
jaa1992's Avatar
jaa1992
St. Jude Donor '12
Well that was the cheap repair - $84 to replace a missing bolt and to tighten others.
The other $4000 on the other hand was not fun :eek: :cry :cry :cry :cry
To 1988 Transmission Problem
