Headlamp switch problem, can the electrical guys help?
Old Jul 14, 2003 | 09:19 AM
LD85's Avatar
LD85
Default Headlamp switch problem, can the electrical guys help?
When the car is running and I turn on the headlamps on the "ding" relay starts dinging like when the ignition is off,,,,,
is the switch bad or the relay?
What else should I look for?
Old Jul 14, 2003 | 11:36 AM
jfb's Avatar
jfb
Default Re: Headlamp switch problem, can the electrical guys help? (ld85)
No schematic at work, but it sounds to me like a wire from the ignition switch to the alarm module is open causing it to believe that the ignition is off with the headlights on. Could also be a defective alarm module.
[Modified by jfb, 10:36 AM 7/14/2003]
Old Jul 14, 2003 | 11:51 AM
corvette-pilot's Avatar
corvette-pilot
Default Re: Headlamp switch problem, can the electrical guys help? (jfb)
:iagree:
Sounds like an open circuit or a wire that has fallen off.
I assume the lights are working correctly?
Old Jul 14, 2003 | 01:26 PM
LD85's Avatar
LD85
Default Re: Headlamp switch problem, can the electrical guys help? (corvette-pilot)
Yes guys the lights are working, I have checked the wiriing but will climb under there tonight and look it over again, I pulled the dash off for a better view and will check it out.
Old Jul 14, 2003 | 02:57 PM
Steve85's Avatar
Steve85
Cruise-In V Veteran
Also be sure to check your circuit grounds very well. Odd occurences such as this are often caused by poor grounds as the little electrons will try to find another way to ground even if it means backfeeding through a different yet related circuit.
Old Jul 14, 2003 | 08:11 PM
LD85's Avatar
LD85
Default Re: Headlamp switch problem, can the electrical guys help? (Ski2Tee)
Dude I gotta shorty to ground somwhere! How do I track it down?
I put my 12v test light to ground and the frame and the light glows just a little.
[Modified by ld85, 8:12 PM 7/14/2003]
Old Jul 14, 2003 | 08:53 PM
jfb's Avatar
jfb
I take it your are putting your test light from the battery negative to the disconnected negative battery cable. Watch the test light and pull fuses one at a time and see if the light goes out. If it does, you found the circuit that has leakage. There are 8 fusible links on the jump start bolt by the battery and you will need to unbolt these and remove them one at a time and watch your test light. Also, there are a number of circuits protected by circuit breakers and a clamp on ammeter on the wires to these breakers will tell you where the leakage current is going.
To Headlamp switch problem, can the electrical guys help?
