Heim Jointed?
Old Jul 14, 2003 | 03:16 PM
cdsmith's Avatar
cdsmith
Default Heim Jointed?
What is the benefit of the Heim Jointed sway bars, trailing arms, toe rods, and camber bars that Exotic Muscle sells. Do they make a noticeable difference in handling?
Old Jul 14, 2003 | 03:34 PM
bogus's Avatar
bogus
Default Re: Heim Jointed? (cdsmith)
Heim joints are just much stronger and a more positive connection. They are also able to move smoother within their range of motion.
Most, if not all, forms of professional racing, and many amatuer, use these to improve handling.
Old Jul 14, 2003 | 04:55 PM
scorp508's Avatar
scorp508
It is tough to say since most of us don't drive our cars to the limit in the first place. :)
Old Jul 14, 2003 | 06:53 PM
jackdaroofer's Avatar
jackdaroofer
From: Almost all Skyline Cruises Vettes at Waterside 1-5
Cruise-In I Veteran
Cruise-In II Veteran
Cruise-In III Veteran
Cruise-In IV Veteran
Cruise-In V Veteran
Cruise-In VI Veteran
Cruise-In VII Veteran
Default Re: Heim Jointed? (bogus)
:iagree: for sure
But for the budget minded, if you are going to larger sway bars, you can simply take your existing links to a machine shop and have them cut off the top tabs (those that bolt to the bar) and have them move and reweld them a 1/4 inch off center...forward for the rear bars and aft for the front bars. This will get them lined up vertically again and make all the diffeence in the world.
Heim is great, but "backyard" can be good too!
:seeya
:steering:
Old Jul 14, 2003 | 07:27 PM
edsalinas's Avatar
edsalinas
St. Jude Contributor
Default Re: Heim Jointed? (jackdaroofer)
:iagree: for sure
:seeya
:steering:
Jack, you continue to amaze me.............
in a good way :cheers:
Old Jul 14, 2003 | 07:32 PM
NavyVet's Avatar
NavyVet
Jack, one of the biggest advangtages of the heim joints on the sway bar end links is so you can: (a) absolutely zero preload the sway bars, or (b) use them to prelaod to a desired point. Either way, it won't happen with the factory end links. One will always be sort of tight.
As said above, using heim joints at the critical control points removes virtually all play/slop from your suspension control arms. I would not recommend them for street use though. Most would not like the additional transfer of the shock/shudder from pavement irregularities directly to the frame and straight to their posterior. If you've done all the right things with stock components and max'd out your car's capabilities, then doen the same with poly everything, then the heims may give that racer on the absolute edge of peak performance the little bit more needed.
Old Jul 14, 2003 | 07:42 PM
jackdaroofer
Cruise-In I Veteran
Cruise-In V Veteran
Default Re: Heim Jointed? (NavyVet)
:iagree: as i said! No doubt they are great, I checked them out carefully at the last cruise in
But, if you are a serious weekender, on a limited budget, moving to larger bars...my simple solution will work..for about $45. Keeping the links vertical at rest, is, I found, critical! When I installed my 30mm fronts and 24mm rears, it became obvious the links weren't vertical and that the upward push from the sway bars was making the links go further off line. In adition, I had a clunk in the front end as a result of the links loading up against the lower control arm. Plus, I really couldn't notice any improvement with the heavier front bars. Being cocked at an angle, the links weren't transferring the force to the bars.
No Doubt Heim is great. But may be a little much for the street and the pocket book.
If links aren't vertical, give my approach a try. I will refund you a $1 bill ifit doesn't work :D :D :D :D
:seeya
:steering:
Old Jul 14, 2003 | 07:49 PM
jackdaroofer
Cruise-In I Veteran
Cruise-In V Veteran
Default Re: Heim Jointed? (edsalinas)
:cheers: Ed, sometimes I amaze myself, and I generally always amaze my wife...usually she doesn't refer to it as amazement, prefering to call it "dismay"!!
:seeya BUD!
:steering:
Old Jul 14, 2003 | 07:57 PM
edsalinas's Avatar
edsalinas
Thanks....
Old Jul 14, 2003 | 08:00 PM
NavyVet's Avatar
NavyVet
:iagree: You are absolutely correct on wanting the links vertical. I'm gald I did the heims, but the heims are a tad expensive for most street cars and for anyone who isn't as obsessed as I tend to be :D
Old Jul 14, 2003 | 08:04 PM
edsalinas's Avatar
edsalinas
Don't forget, heims ware out too.....
Sooner than poly's? don't know.............
But they look so damn coooooool........ $$$$$$$
To Heim Jointed?
