DFI 6.32
Old Jul 14, 2003 | 07:17 PM
xxxtremevette's Avatar
xxxtremevette
6th Gear
Default DFI 6.32
Does anyone have a good program to run:
406ci
solid roller cam
strip dominator intake
ported heads, larger valves
42.5lb/hr injectors
Old Jul 14, 2003 | 08:14 PM
vette_tweak's Avatar
vette_tweak
Default Re: DFI 6.32 (xxxtremevette)
x, I've messed with my DFI 6.32 and 420 stroker quite a bit and the best advice I can give you is to use the DFI utility to spit out a base fuel map then get the car on a dyno for final tuning. Trading DFI setups is a waste of time because no one's setup is identical. :cheers:
