Double Roller Timing Chain Possible on LT4 ?
Old Jul 15, 2003 | 11:14 PM
Rex Ruby's Avatar
Rex Ruby
Philly 'Burbs Events Coordinator
Default Double Roller Timing Chain Possible on LT4 ?
Posting this for a friend who doesn't have access.
Does anyone know if there is any way to run a double roller timing chain on an LT4 based optispark and timing gear set? It seems as though something could be done with the longer dowel on the end of the cam but ??
:cheers:
Old Jul 16, 2003 | 02:01 AM
NavyVet's Avatar
NavyVet
Default Re: Double Roller Timing Chain Possible on LT4 ? (Rex Ruby)
You might want to try the GMPP Extreme Duty Timing Set #12370835 - designed for very high output LT1/LT4 engines. I have one. I don't know of a double roller that fits.
Old Jul 16, 2003 | 02:06 AM
superlund's Avatar
superlund
Default Re: Double Roller Timing Chain Possible on LT4 ? (NavyVet)
Some people do run a Std double roller chain on the LT series motors. I know they dump the gear drive for the water pump & then run an electric water pump. I don't know what else is involved.
Old Jul 16, 2003 | 09:09 AM
silver & red CE's Avatar
silver & red CE
Default Re: Double Roller Timing Chain Possible on LT4 ? (superlund)
...they dump the gear drive for the water pump & then run an electric water pump....
Yup, the standard GenI timing chains don't fit under the GenII (LT1/4/99) timing chain cover, to use a low cost double chain the LT1/4 timing chain cover has to go, the older GenI cover is used, that means no drive shaft for the H2O pump, hence the electric H2O pump requirement.
Eric
Old Jul 16, 2003 | 10:30 AM
superlund's Avatar
superlund
Default Re: Double Roller Timing Chain Possible on LT4 ? (silver & red CE)
How do they drive the opti with a Gen-1 cover?
Old Sep 9, 2019 | 03:48 PM
lt4 coupe's Avatar
lt4 coupe
Sorry to Necro-post but this is my exact issue. I have an LT-4 and I already have the electric water pump so I just need to plug the hole in the cover and get a chain. Can you run an L-98/TPI double roller in the factory LT-4 cover so you can run the Opti? Or just run a standard SBC single roller?
Old Sep 9, 2019 | 06:42 PM
dizwiz24's Avatar
dizwiz24
Run the LT4 extreme duty timing set.
i have heavy valve spring pressures and this works great
If you go this route, dont be one of the camaro ‘dummies’ that tries to reuse the stock water pump drive gear (and then gets mad bc of metal shavings ruining your engine)
you have got to install the special water pump drive gear included in the kit ! Its softness/hardness is correct for the gear set
Old Sep 9, 2019 | 08:11 PM
lt4 coupe's Avatar
lt4 coupe
Im running Mezierre electric, deleting all of that crap. I was told the L-98/TPI single roller would built right in. Sounds like it makes sense?
Old Sep 9, 2019 | 08:19 PM
dizwiz24's Avatar
dizwiz24
if you trust electric water pumps and there ability to cool then yes ! (I dont)
Old Sep 9, 2019 | 09:31 PM
STL94LT1's Avatar
STL94LT1
I'm running a Cloyes 9-3145 double roller timing set in my LT1/Meziere pump.
Old Sep 10, 2019 | 12:16 AM
lt4 coupe's Avatar
lt4 coupe
How much clearancing was required?
Old Sep 10, 2019 | 12:20 AM
lt4 coupe's Avatar
lt4 coupe
I got ther larger HD version, they say it's near 100% reliable. Only problem would be road racing, which im not doing. Mostly just daily drive and occasional drag racing, which is PERFECT. I can leave the water pump and fans running to keep the motor at exactly the temp I want while in the staging lanes.
Old Sep 10, 2019 | 08:30 AM
dizwiz24's Avatar
dizwiz24
Ive seen posts where people have made road racing in the electric pump work by using an upgraded radiator!
Old Sep 10, 2019 | 08:33 AM
STL94LT1's Avatar
STL94LT1
Some timing covers will require a small amount of clearancing, mine did not.
Old Sep 10, 2019 | 11:24 AM
lt4 coupe's Avatar
lt4 coupe
Interesting, Mezierre said the electric, pumps water at the same amount the mechanical does at 3000 rpms. After that, the mechanical has the advantage.
That's why electrics are so nice for daily drivers and cars that get hot sitting in traffic (or drag racing). At idle, you now get more water flow than the mechanical supplies at freeway rpms.
To Double Roller Timing Chain Possible on LT4 ?
