What would you do? ZZ4 or modified 91 Corvette engine?
I have 2 options:
Option #1:
Ken Smith (L98Terror) replaced his engine about a month back and has offered me to buy his old engine minus the intake (A Superram).
This 350 motor was from his 91 Corvette and has a little over 100k miles on it. This motor is a consistent mid 12 second engine with Aluminum #113 Ported heads, ZZ9 Cam, Roller Rockers, ect, for what ever reason it's a freak.
Said and done I'm looking at around $2,500. 1,000 for the engine (damn good deal), another thousand for the work on it (Bearing/Rings & Honing) and around $500 for misc parts.
As for the intake I was thinking of using the one off my existing motor, a Ported base/Plenum & AS&M Runners.
I will also need a set of long tube headers, another $700.00 for the Hookers with Y-Pipe.
Total approx: $3,200.00
Option #2
Just buy a new crate motor, ZZ4.
http://www.sdpc2000.com/cart.asp?act...id=120&pid=117
Minus the intake of course, I subtracted $200 (again I'd use my Intake).
I would still need headers so add another $700.00 to it.
Total approx $4200.00 + shipping. I would shop around more to find the best deal I can on this engine, but the ZZ4 would be my choice.
Any thoughts?
P.S. My Corvette is a non roller block '86. :(
[Modified by Mr. Magoo, 7:55 AM 7/16/2003]
The heads on my Vette are.......*gulp* 305 Iron heads. The **** hole owner that I bought my vette from swapped the existing aluminum heads and replaced them with these garbage heads without me knowing. But that was 8 years ago and I'm just chalking that one up as a lesson learned. :(
The short block ZZ4 sounds like a good option though. Hmmmmmmmmmmmmmmmm decisions??
I'd go with the ZZ4 shortblock, basically because of the Warranty and craftsmanship. BUUT..you don't have #113 OR #128 heads...so...if you bought that shortblock, you'd still need heads...just get some Pro Topline's :D
EDIT:
WAAAM!
http://sdpc2000.com/cart.asp?action=...id=514&pid=622
[Modified by TIMSPEED, 7:11 AM 7/16/2003]
EDIT:
WAAAM!
Shortblock= $2000.00
Ken's Heads/Cam= $1,000
Headers= $700.00
Misc parts= ? (Water Pump, Dist, Timing, ect) A lot of extra money and time for assembly.
:p: :D
Fine. But my cars not get any faster. I'll leave my cadillac to destroy you!
:p: :D
I would consider buying the used engine and have it freshened up.
A new ZZ4 engine will not have ported heads but stock L98 heads.I do know the ZZ4 engine has beefier or stronger internal parts,but still,think of it as a L98 motor with a ZZ4 cam and carb intake,which is why it makes 355 HP.Put a TPI on there and it will choke back some,even with large tubes and ported intake.Buy the ZZ4 then get the heads done will be alot more money.
With the used motor,you already know it runs good and is a bit cheaper and wont cost too much to make it a bit stronger or freshen up.The ZZ4 short block is a good choice but youll still need better heads,cam and misc parts.
Just my 2 cents.
Forged pistons
Forged connecting rods
Piston Rings
Oil Pump
Bearings
Headers
..spray it till it dies. :reddevil You can get KILLER deals usually for rods/pistons on eBay.
I would go with the other option you listed. It has already most of the expensive work done (research, porting and testing) and you only need to freshen it up.
Toni
[Modified by ToniH, 11:07 AM 7/17/2003]
Forged pistons
Piston Rings
Oil Pump
Bearings
Headers
What Forged pistons & Forged connecting rods would you recommend? I do plan on spraying the crap out of this motor so I will need a strong bottom end.
Forged pistons
Piston Rings
Oil Pump
Bearings
Headers
:thumbs:
definetly buy the used motor and rebuild it. Definetly the best deal going that you have listed.
