Automatic Leaking at shifter shaft
Old Jul 16, 2003 | 11:23 AM
dobie1996's Avatar
dobie1996
1st Gear
Default Automatic Leaking at shifter shaft
How hard is it to change out the shifter seal on a 96 LT1. A tranny repair shop what 3 hrs labor because they have to remove the exhaust.
Old Jul 16, 2003 | 11:50 AM
nitrous1's Avatar
nitrous1
St. Jude Donor '06-'07-'08-'09
Default Re: Automatic Leaking at shifter shaft (dobie1996)
I haven't done one of these on a Corvette yet, but I have done a couple of 700R4's in other vehicles. You have to pull the pan and remove the shaft from the case. If you don't mind getting really dirty and aren't afraid to open up the tranny, go ahead and do it. The seals are only a couple of bucks. The exhaust shouldn't be that big of deal - just make sure to soak all the bolts a few days in advance with penetrating oil. I would probably attempt it myself, but then again I'm a glutton for punishment.
Dan
Old Jul 16, 2003 | 08:18 PM
RED84CF's Avatar
RED84CF
Default Re: Automatic Leaking at shifter shaft (nitrous1)
Had my outside shifter shaft seal changed, still leaked. Than tranny was rebuilt after it exploded, still leaks a little little bit not sure where comimg from going back in next week for state inspection and to have that checked.
[Modified by RED84CF, 7:19 PM 7/16/2003]
To Automatic Leaking at shifter shaft
