I post in this forum couples week ago.my 92 vette engine shut down by itself
halfway thru my garage. it crank but Won"t start. I check fuel pressure it show 40 PSi.fuel filter, spark plug and wire already replace since 30,000 miles now it got 41,000 miles.I pull 1 spark plug wire out and start the engine
their no spark at all.could it be my igniton coil or distributor went bad.HELP
Thanks!
Ok I already replace ignition coil, still cannot started.now i"m looking to replace opti-spark. should I replace opti-spark distributor cap kit only or the whole unit. the kit cost $229 and unit $489.Thanks vette92_1 for responding.
No problem, I'm definately not the person to be giving advice on your problem, I know just enough to get me in trouble :D
Your are saying that you have no spark at all? Is there anyway you can have it diagnosed? I'm sure if the opti goes completely out you would get no spark. Did you have any symptoms before the no start? Like the typical opti symptoms are kinda like cutting out, but sometimes only at high rpm's.
I'm probably not going to be able to help, but as for your 2nd question, If it were me I would buy the complete unit if I was going to do anything with opti, for one you don't want to have to go back in there again. Also, I would look into the Dynaspark system if I was going to replace it.
If you are looking to buy a new Opti for your '92 - I got a new AC-Delco unit (complete with cap) from Jason Cromer at Sam Taylor Buick in Florida for $288 DELIVERED for my '92!! Here's the link - check him out!! http://www.samtaylor.com/html/parts.html
