speedo correction
Old Jul 17, 2003 | 10:17 AM
jodyeastman's Avatar
jodyeastman
Default speedo correction
I just purchased a Richmond 3.75 ring and pinion with Bear master overhaul kit. It's a 1994 automatic so the speedo correction is electronic. I know most guys use a reprogramer like hypertech. I called the local dealer here and he said that they could get the codes from GM and "simply" do it there. Anyone ever try this?
Old Jul 18, 2003 | 10:16 AM
jodyeastman
Default Re: speedo correction (jodyeastman)
From Roger Walter's "anybody out there?" :party:
Old Jul 18, 2003 | 10:25 AM
redvette1986's Avatar
redvette1986
My car is far less evolved than yours I'm guessing because reprogramming capability is very limited. I Changed from 3.07s to 3.73s and a speedo shop installed a "little black box" which they hard-wired into the circuit. I have since gone back to the original gears so, if you want it and it works for your situation, you can have the box for $100.
To speedo correction
