94 front brake pads
Old Jul 17, 2003 | 11:08 AM
rockken_vette's Avatar
rockken_vette
Default 94 front brake pads
I went to replace the anti rattle clips and was shocked by what I found:
My car has 96k miles.
The previous owner replace pads at 59k, just before I bought the car.
(i don't know if they were stock, though they looked factory)
I noted the following before taking everything apart:
(a) - the pads clicked sometimes when applied at low speeds
(b) - pads rattled over bumps
(c) - rotors appeared to wear evenly, no grooves, only the slightest
pulsation or hint of warping, only under the lightest braking
(d) - lots of brake dust through the vanes on my wheels.
I observed the following as dissassembly:
(1) - brake pad pins were slightly worn where they contacted the pads
(2) - antirattle clips looked tired
(3) - the metal part of the pad where the pin goes through was
extremely worn, so much so that replacing the pin and the clips
still allowed the pads to rattle slightly.
(4) - the pads were worn unevenly, ie the pad thickness from front to back
was not the same, and opposite for inner to outer pad, as if the caliper
was not perpendicular to the rotor.
(5) - caliper bracket appeared properly located wrt the rotor.
(6) - antisqueal shims installed on pads
I put everything back together temporarily with a new pin and clip, and the bump rattle went away 85% of the time, and they don't click any more, and although they are safe for now, I need new pads ASAP.
now for the questions:
Can anyone comment about the following:
- Stock pads from GM ($121)
- Hawk HPS pads ($89)
- EBC Greenstuff ($79)
I do spirited driving only, summer and winter in VA.
I may do and autocross once or twice. I'm concerned
about brake dust, wear, stopping power, and brake feel
What about Rotor prep:
- Should I have them lightly cut (I think so)
- Must I have them cut if I change composition
- what surface finish is best for bedding new pads? who does this?
What about uneven pad wear? what causes that?
Thanks for any input.
Ken
Old Jul 17, 2003 | 05:51 PM
John Row's Avatar
John Row
Default Re: 94 front brake pads (rockken_vette)
Mine does this too.
I had EBC Green Stuff. My only complain was that the pad wear squealer gouges the rotors before it makes any noise. Other than that, they worked very well. They don't dust as much as most other pads don't sqeak and stop well.
At to the turning of the rotors, this is almost a religous war. Some swear by 100grit sand paper to deglaze, some swear by turning. Some swear at each other.
For about $55 each ( I think that's about the going price now), I'd put new ones on. Turn the old ones. Save them for spares.
Me too.
Old Jul 17, 2003 | 09:06 PM
Mr Mojo's Avatar
Mr Mojo
Elite Torch Red Member
Cental/South NJ Events Coordinator
CI 1-2-3-4-5-6-7-8-9-10-11-12 Vet
CI-II Burnout & Drag Champ
St. Jude Donor '03-'04-'05-'06-'07
Well from what I've heard, you shouldn't turn the rotors, but replace them with new.
My opibnion-stock car=stock brakes. I'm actually going to give the Green Stuff a shot because I want something different. I have the NAPA Ceramix pads now and they are starting to wear the rotors down a bit.
Old Jul 18, 2003 | 11:16 AM
John Row's Avatar
John Row
Default Re: 94 front brake pads (Mr Mojo)
...I have the NAPA Ceramix pads now and they are starting to wear the rotors down a bit.
The EBC Green Stuff's were very soft on the rotors, right up to the point where the squealer hit the rotor.
Old Jul 18, 2003 | 12:43 PM
87Z-ya's Avatar
87Z-ya
Default Re: 94 front brake pads (John Row)
I put performane friction Z rated pads. Were 69.99 and will make your eyeballs want to pop out on extreme braking once heated up.
Old Jul 18, 2003 | 12:48 PM
rcolling's Avatar
rcolling
Now he tells me... :smash:
I switched several months ago from the NAPA Ceramix to EBC Greenstuffs because of price and what I had heard on the forum. The stopping performance seems to be about the same, neither one squealed, dusting on the Greenstuffs is worse than the Ceramix but not too bad.
Old Jul 18, 2003 | 03:29 PM
rockken_vette
Thanks so far,
I definitely don't want to have to heat the brakes up, my commute to work is but 6 minutes as it is! (perhaps I'll just have to drive away from work first, then go to work. More seat time! :lol: )
Anyone else have the problem with the backing plate wearing at the pin?
John Row, how long did you drive it scraping thinking it would be okay? Did it really destroy the rotor that fast?
If I were to get new rotors, are those $55 ones any good? Where are they from. I know a lot of people say the cheaper rotors are junk. I saw nice looking powerslot rotors for $99 each. Are they worth anything besides show?
I might lean towards the sandpaper method. The ones I have really are pretty good.
Keep the replies coming!
Ken
Old Jul 18, 2003 | 03:31 PM
champ's Avatar
champ
I went with the stock GM pads on my 94. Cost a little more but no NOISE WHATSOEVER. Also pleased with the performance.
Old Jul 18, 2003 | 04:48 PM
John Row's Avatar
John Row
Thanks so far,
The first thing I heard was the scraping of metal to metal. The problem was the base of the squealer was rubbing on the rotor before the tip. I was able to have the rotor machined and reuse it. It happened at about 20K miles. The rear ones did the same thing at about 12K miles.
The $55 rotors are fine. Slots are suppose to let gases escape. Holes are supposed to help cool, but I think they just reduce surface area. They look cool, if that's what you are shooting for.
To 94 front brake pads
