727 vs 730???
Old Jul 17, 2003 | 01:51 PM
drive it's Avatar
drive it
Default 727 vs 730? and 730 swapQ's
Now that the really hot weather is here-the maf is having a hard time surviving sitting next to the SC! So I'm finally going to do the speed density swap.
I need to clarify the diff between 730 and 727 ecms however...
As I understand it, one is "weatherproof" for under the hood and has 4 vs 3 connectors?
Also are the physical dimensions the same? I'm planning on keeping it up under the dash.
After more phone calls to boneyards etc....looks like I can get a 7730 ecm (same ecm, connectors as 90 to 92 camaro?) out of a corsica with the three connector plugs and a couple feet of wire cut off the engine harness.
So correct me here if I'm wrong.....I need an ecm pinout diagram from a 90 to 92 camaro (along with my 86); and are the pins the same-just pop them out of the original connectors and pop them in the plugs that I get from the boneyard?
Thanks!
[Modified by drive it, 12:49 PM 7/17/2003]
[Modified by drive it, 12:52 PM 7/17/2003]
[Modified by drive it, 12:54 PM 7/17/2003]
Old Jul 17, 2003 | 04:45 PM
HighHopes85's Avatar
HighHopes85
Default Re: 727 vs 730? and 730 swapQ's (drive it)
Go with the 730 if you want it to be an easy swap and you are going to mount it inside the car.
The pins are the same shape, so yep. Just pop out and pop in.
You will need that extra third connector, so take it graciously if the junkyard is going to give it to you.
Correct about the diagrams. Schematics at the bottom of this page. http://www.diy-efi.org/gmecm/ecm_info/1227730/
Also, shoot up "730 Club" in the search engine in archived topics and check out some info there on VSS, etc.
Old Jul 17, 2003 | 04:58 PM
drive it's Avatar
drive it
Default Re: 727 vs 730? and 730 swapQ's (HighHopes85)
Great, thanks!!! And oh yea, I've been searchin the archives.....
Another thought-camaros don't have vats...so for pinout of vats on 730??? Or do you just uncheck it in the prom and do without? Lookin' like I've got most everything else figured out.
Just printed out those diagrams...so the 730 does have a vats input!?
[Modified by drive it, 2:11 PM 7/17/2003]
Old Jul 17, 2003 | 10:36 PM
HighHopes85
Pretty sure it has VATS. I din't, so I only had to uncheck VATS in the ECM...on a friend's 89 IROC, he had a problem with his factory VATS. I had to toggle the flag and also hardwire the VATS relay. So you may also have a bit of hardware to take care of depending on how VATS was handled on the later ECMs.
Old Aug 12, 2003 | 01:05 PM
Black87c4's Avatar
Black87c4
if your running a supercharger i'd go with the 749 ecm with a 2 bar map and ditch the extra fuel man. crap that comes with the sc.
http://www.efi-tuning.org
Old Aug 13, 2003 | 01:24 AM
drive it's Avatar
drive it
Default Re: 727 vs 730? and 730 swapQ's (Black87c4)
If I could I would....but I still need to keep all smog equipment functioning to pass-and the 749 doesn't support all of it. So still using the fmu and tuning with a wide band. Started on the project now....not goin' too bad-just wish I was better at soldering!
Old Aug 14, 2003 | 02:06 PM
ELEVENS's Avatar
ELEVENS
"Third connector"? My 1990 has a 730 with 4 connectors.
Old Aug 14, 2003 | 03:56 PM
drive it's Avatar
drive it
Default Re: 727 vs 730? and 730 swapQ's (ELEVENS)
That should be the 727 under the hood with weathertight connectors then....
To 727 vs 730???
