Fuel injectors for a 91
Old Jul 17, 2003 | 07:03 PM
darkred91's Avatar
darkred91
Default Fuel injectors for a 91
I'm in the market for some new fuel injectors, but I have one question should I buy 21lbs or 24lbs injectors. also I'm buying a new fuel pump, and fuel preasure regulator. 1991 L98 K&N openlid filter. TB air foil, MSD coil & wires, no pre Cats, no water pump disc..
Old Jul 17, 2003 | 10:17 PM
Stingray1970's Avatar
Stingray1970
Default Re: Fuel injectors for a 91 (darkred91)
I've got the 24# SVO'S in my 91. had them for about 35,000 mi and they work great. I think it's the best buy for the money.
Old Jul 17, 2003 | 10:22 PM
vader86's Avatar
vader86
I would get the Ford #24s, theyre cheap and high quality, but use the AFPR to turn down the pressure just a little to help the computer compensate.
Old Jul 17, 2003 | 10:33 PM
6spd's Avatar
6spd
Default Re: Fuel injectors for a 91 (vader86)
hi, i have a 91 vette and i'm looking to use the 24#ford injectors but some people say you need a custom chip and others that used them said they work find with the stock chip
Old Jul 17, 2003 | 10:44 PM
vader86's Avatar
vader86
Default Re: Fuel injectors for a 91 (6spd)
Custom chips are not necessary for the #24s. The ECM can compensate by itself for that extra fuel, but, its likely to run on the rich side. So, install an adjustable pressure regulator and turn the pressure down on the Fords to HELP it compensate and it'll run like a champ.
To Fuel injectors for a 91
