MOVIT BRAKES
Old Jul 18, 2003 | 12:45 PM
vettethret's Avatar
vettethret
Default MOVIT BRAKES
Does anybody know what the cost is for the front that will fit under the grandsport wheels. I've sent these idiots 3 dufferent requests on there websit and havn't gotten one response. Is this the way these people do business. Has anybody had experience with SSBC 4 piston system. There not much more than the c5 upgrade and was seriously considering this. I want more braking power than the c5 upgrade but dont want to spend a rediculous amount of money on a car that will never see the track.
Thanks guys :cheers: :flag
Old Jul 18, 2003 | 01:30 PM
Jeffvette's Avatar
Jeffvette
From: No more yankee my wankee, the Donger is tired!
Default Re: MOVIT BRAKES (vettethret)
You just answered your own question. There is no need to go bigger unless you are tracking the car, and that is heavily tracking.
With that being said, check out Exotic Muscle for their kit, which is the one I am running.
Old Jul 18, 2003 | 01:45 PM
vettethret's Avatar
vettethret
Default Re: MOVIT BRAKES (Jeffvette)
That looks great. I looked on there site and it looks like the Movit package. Do you know what size pistons are on the 4 piston set up? SSBC brakes has a 4 piston 43 mm for $1300 with rotors. How does the car stop? Dou you have anything done to the raer? Thanks for the response.
Mike :cheers: :flag
Old Jul 18, 2003 | 01:52 PM
Jeffvette's Avatar
Jeffvette
The pistons are a 36mm and a 32mm if I remember correctly
The problem with larger pistons it will require more fluid to move those pistons, which will sometimes mean an external proportioning valve.
Haven't had a chance to drive on mine yet, but it stops like the hand of god came down and stopped you. Based on others.
Do you have anything done to the rear?
Went to the 4 piston rear set up with a 13" rotor in the back.
Old Jul 18, 2003 | 01:58 PM
vettethret's Avatar
vettethret
Is it a bad thing to have an external proportioning valve? You would think with bigger pistons you might have to change out the master cyclinder, but it doesnt say that on there sight. :thumbs:
Old Jul 18, 2003 | 02:00 PM
Jeffvette's Avatar
Jeffvette
Most race cars require one, so no it's not a bad thing
Old Jul 18, 2003 | 02:14 PM
K87ZZ4's Avatar
K87ZZ4
As Jeffvette pointed out, if the car is not going to be run on the track, what makes it worth it to you to invest all the extra time and money into a brake system that's going to stop just a few feet shorter and won't fade (which won't matter to you if you're not on the track)? :confused:
Seems to me that $1,300 would be well into "ridiculous", but then I guess it's all relative :D
Old Jul 18, 2003 | 02:41 PM
vettethret's Avatar
vettethret
Default Re: MOVIT BRAKES (K87ZZ4)
Well since the c5 upgrade is 1k and the SSBC is $1300, that's a $300 swing. I'm getting and extra 2 calipers for an extra $300. I brake very aggressive on the street and wanted the most power without spending 4k. The only problem is I dont think that anybody with a c4 on the forum has used them so I dont know about the quality. :party: :cheers:
Old Jul 18, 2003 | 11:18 PM
1991Z07's Avatar
1991Z07
Try Gene at Electro-Dynamics http://www.electro-dynamics.com.
They have basically the same kit, with some Acrobat templates you can download to see if they'll fit.
Their customer service is a lot better as well, plus he's one of us...Gene284 is his Forum handle. Give him a shout.
Old Jul 19, 2003 | 01:29 AM
JordiZR1's Avatar
JordiZR1
Default Re: MOVIT BRAKES (Joe90)
I have MOVIT Brembo brakes in my car, absolutely satisfied with them.
I would give them a call, the number is in their website, ask for Guido (owner), he is a nice guy.
To MOVIT BRAKES
