left turn signal / rear problems!! help!
Old Jul 18, 2003 | 01:46 PM
96KICKS's Avatar
96KICKS
CI 7-8 Veteran
St. Jude Donor '03-'04-'05-'06-'07
Default left turn signal / rear problems!! help!
Hi everyone,
Got a problem with left turn signal and rear inside tail light. No blinking when I turn on left signal at all, the light just stays on. Both inside on the dash, and on the outside lights. Along with that, as I was checking all the lights, the left inside tail light is not lit up at all, not with turn signal, braking or with the emergency flashers on. Any ideas and hopefully an EASY solution! Thanks for any help you can give me.
Old Jul 18, 2003 | 01:54 PM
Jeffvette's Avatar
Jeffvette
From: No more yankee my wankee, the Donger is tired!
Default Re: left turn signal / rear problems!! help! (C4Girl1996)
Check your bulbs. More than likely you have one burned out. Which will cause it not to flash.
Old Jul 18, 2003 | 03:27 PM
JCAIRE2's Avatar
JCAIRE2
Default Re: left turn signal / rear problems!! help! (Jeffvette)
:iagree: Should be an easy fix :cheers:
Old Jul 18, 2003 | 06:34 PM
96KICKS's Avatar
96KICKS
CI 7-8 Veteran
Default Re: left turn signal / rear problems!! help! (JCAIRE2)
You were OH SO RIGHT! Thanks.
To left turn signal / rear problems!! help!
