90 Lower hose replacement
Old Jul 19, 2003 | 04:42 AM
gpagaduan's Avatar
gpagaduan
Default 90 Lower hose replacement
What do you need to remove to have enough access to get the new hose back on the water pump? I checked the archives and DIY post appears to be for a pre 90 model, which seems to be easier to access if you remove the radiator...not applicable to me. GM Service manual not much help either..."remove clamps, remove hose, attach new hose, tighten clamps" B.S.!!! I'm thinking I need to remove just as much crap (i'm a little frustrated) as if I were wanting replace the water pump itself, just to have access and leverage to slip the new hose back on. :confused:
Old Jul 19, 2003 | 07:55 AM
ELEVENS's Avatar
ELEVENS
Default Re: 90 Lower hose replacement (gpagaduan)
I don't think you have to remove anything. Just jack it up to the moon, and access the hose from down-under.
:cheers: -Bill
Old Jul 19, 2003 | 08:44 AM
90Z51Vette's Avatar
90Z51Vette
Default Re: 90 Lower hose replacement (ELEVENS)
:cheers: -Bill
:iagree:
Old Jul 19, 2003 | 11:16 AM
gpagaduan's Avatar
gpagaduan
:cheers: -Bill
That may work to on the radiator end but not the water pump end. No daylight between the waterpump and the floor.
Old Jul 19, 2003 | 04:13 PM
gpagaduan's Avatar
gpagaduan
Figured it out...need to remove the tensioner. At first glance it doesnt look like it will add that much access, but its just enough to allow me to wiggle and push the hose one. WHEW!!! That took a lot of energy. :)
To 90 Lower hose replacement
