Modding the LT1?
Old Jul 20, 2003 | 12:18 AM
Bat Man's Avatar
Bat Man
Default Modding the LT1?
So far my LT1 has K&N with cut lid, muffler elims, and some weight reduction.
I want to get a bit faster. Like 375-450 hp like.
What to do? How can you acheive that?
Anyone have a SC'd LT1?
Old Jul 20, 2003 | 12:26 AM
blk95's Avatar
blk95
Default Re: Modding the LT1? (Valleybacker)
RWHP or FLYWHEEL
anyhow, Heads and Cam package, full exhaust..
Old Jul 20, 2003 | 12:53 AM
Lone Ranger's Avatar
Lone Ranger
Don't supercharge unless you beef up the bottom end for it. Otherwise it'll kill the stock LT1 sooner than later, if you run any kind of boost at all.
Do stage II heads w/ 1.6 roller rockers, a more aggressive cam, long tube headers, corsa catback exhaust, random 3" bullet cats (keep it emissions friendly okay?), have the intake matched up to the heads as well as possible, add a 52mm throttle body. To bring it all into harmony you'll need a good custom dyno tune job on your ECM chip.
Tired (note hour of post) have I forgot anything?... 2400rpm stall tc if an A4 car... 4.10 gears if an M6. 3.07 gears if an A4... new set of Taylor plug wires and maybe a slightly hotter coil unless you have a '96 in which case the stock coil is adequate (they upgraded it for '96). I bet he would also benefit from stronger injectors and an AFPR with such a setup (?)
[Modified by Lone Ranger, 11:56 PM 7/19/2003]
Old Jul 20, 2003 | 02:06 AM
RadPolo96's Avatar
RadPolo96
Default Re: Modding the LT1? (Lone Ranger)
:iagree: Seems like you covered it all :thumbs:
Old Jul 20, 2003 | 08:32 AM
vader86's Avatar
vader86
Longtube headers, 4.10 gears, LT4 Hotcam and 1.6RR
That should get you to the 375rwhp level.
Head porting and matching the manifold will get you more. Picking another, larger duration cam will get you more too, like the CC306.
Dont mess with a SC unless youve changed the pistons and rods for it. I would not put more than 100shot of juice on the LT1 either, more like 50shot.
Old Jul 20, 2003 | 08:56 AM
STL94LT1's Avatar
STL94LT1
Default Re: Modding the LT1? (vader86)
[QUOTE]Longtube headers, 4.10 gears, LT4 Hotcam and 1.6RR
That should get you to the 375rwhp level.QUOTE]
Maybe 375 flywheel hp, not 375 hp at the wheels.
Old Jul 20, 2003 | 11:17 AM
Bat Man's Avatar
Bat Man
Sounds like a plan guys, now I just gotta start saving up.
How much have you all spent on modding the lt1 so far(heavy modding?)
And did you do the work yourself?
Old Jul 20, 2003 | 01:07 PM
vader86's Avatar
vader86
Default Re: Modding the LT1? (STL94LT1)
Correction, 340rwhp. 379 if you put on 1.7RR and had the heads ported.
http://www.wku.edu/~nathan.plemons/h..._corvette.html
Old Jul 20, 2003 | 02:37 PM
Bruce's Avatar
Bruce
There are plentiful supercharged LT1 here. :)
Bruce
Cog drive is coming very soon
93LT1 Conv w/ZF6
Blown D1-SC/N2O
ARE built 383ci/Stage II heads
Old Jul 20, 2003 | 09:59 PM
1eo's Avatar
1eo
Before you start doing "heavy modding" you should do all the bolt-ons.
(I have an Lt-1 but in a Camaro)
lets see, I'm probably doing (hoping ;) ) 320rwhp and I ran 12.8s at 105.89 with my old TC.
Let me name some ## of what I have spend until now :D
$600 long tube headers (powercoated) (Installed myself)
$300 custom "Y" pipe (installed)
$550 Hotcam kit (cam, 1.6RR, springs...) I was a newbe and they rip me off $1000 for the install :skep:
$720 Vigilante 3600 Torque Converter.
$900 bullet proof transmission rebuild (I got a hook up on the price..ohh and that includes a shift kit, and a tranny cooler)
Those prices are not inlcudding S&H pluss you need to add all the little things that you need to up-grade or remplace... they add up real fast like (lets see) plugwires, coil, spark plugs, new opit (if you're doing a cam, get an new opti and save the truoble), heavy duty timing chain, custom programing, ET streets.... Pluss All the errors and mistake that you make.
Example. Trying to save a few $$$ I bought a "torco" Torque Converter $300. They owner of torco promesed me the strongest, most durable, bulletproof Torque converter that I could find for and incredible price! Unfortunately the TC broke and destroyed my new rebuilded transmission. Traying to save some money I finish paying for another transmission rebuild and having to buy a real ($720) TC "Vigilante". Troco gave me my money back for the TC (They would not pay for my tranny)
Right now I bought a set of Lt-1 heads and I'm getting them ported. My plans are to build another LT-1 engine (with a bigger cam, all forged internals. you know the deal)... when I'm done with it I'll just droped in my camaro and sell the other engine or find another body for it. My new plans are 420 rwhp and then a 200-300 shot of nitrous for the track.
700rwhp in a daily driver must be fun! :crazy: :smash: http://www.terephoto.com/camaro/
leo
Old Jul 20, 2003 | 10:11 PM
1eo's Avatar
1eo
Default Re: Modding the LT1? (1eo)
OMG!! I just started summing up all the money that I have spend on my car! :eek: :eek: I have an adiction problem :skep:
I didn't even include the all the other extra stuff like an set of extra rims for my Et-streets, or the "just in case" rear end (just in case I break the rear end), or the new battery or the new alternator or the $2000+ in stereo system, or the gauges (fuel press, tranny temp, air/full ratio) :leaving:, or the B&M shifter, or the new brakes and rotors. :rolleyes:
OMG I'm addicted :nopity
Old Jul 21, 2003 | 12:51 AM
BAM92's Avatar
BAM92
For less than the price of a head, cam upgrade you can put a brand new blower built for a 92 vette that will get you to 425 hp. It is on ebay listed by a forum member. Very complete kit, it used to be mine until I reluctantly had to sell it before I installed it. Just a thought.
Old Jul 21, 2003 | 12:57 AM
mackeyred96's Avatar
mackeyred96
From: Former NCM Drag Racing coordinator, National director Corvette Challenge Spring Hill, Tennessee: Whiting, New Jersey
Cruise-In VI Veteran
Cruise-In VII Veteran
Good job guys , sound like you all have this LT1 sorted out.
I'm waiting to see the results. :thumbs:
Old Jul 21, 2003 | 04:08 AM
TIMSPEED's Avatar
TIMSPEED
Default Re: Modding the LT1? (mackeyred96)
I was going to suggest Nathan Pleamons's setup aswell...where has he been lately??
Just FYI, if you throw in a set of 3.73 gears/3000rpm stall converter, then add on a set of long tube headers/no cats/replace the resonator with a dual in dual out race muffler, then replace your main mufflers with straight pipe, as well as add some sort of air filter kit...I'm sure you'd be happy with your results (read: you'd run mid/low 12's)
To Modding the LT1?
