Voltage Drain?
When the car is running with no accessories on, the digital dash works great, but turn on the lights, or the AC/Heater, or signal lights, in fact just about anything, and the fun begins.
1. Oil pressure reading drops dramaticly.
2. Engine temp reading rises dramaticly.
3. Low voltage warning comes on.
4. Low oil pressure warning comes on.
I've had everything above checked with manual gauges, and all is well.
Have had new alternator installed....no change
Installed a new battery with a new ground strap....no change.
Instrument cluster has been rebuilt...no change.
Serpentine belt is good and tight.
I'm getting used to this nonsense now, and I know that all systems are functioning properly, in spite of what the gauges say, but it is getting annoying.
If anyone out there in tech land has any ideas, suggestions, cures, etc. I sure would appreciate any help thrown my way. Thanks in advance!
Larry
I still think the belt maybe an issue. The spring tensioner looked like it was near the end of it's travel. How old is the belt? Could be slipping even if it is tight. I ended up putting a slightly shorter belt on mine that got the tension back in spec. I can give you the size if you want it.
