85-88 COLD START INJECTOR?
Old Jul 21, 2003 | 02:45 AM
007rollie's Avatar
007rollie
Default 85-88 COLD START INJECTOR?
When looking for information on large tube runners, i found there is a difference between 85-88 & 89-91. Where is this cold start injector? what is its purpose? Can it be removed without causing problems? Can you make 85- 88 runners work on 89-91 by removing Cold start injector? If so how?
[Modified by 007rollie, 7:47 AM 7/21/2003]
Old Jul 21, 2003 | 10:10 AM
dgoodhue's Avatar
dgoodhue
Default Re: 85-88 COLD START INJECTOR? (007rollie)
The cold start injector is on the driver side between the runner on the intake manifold. To bypass it using 85-88 runners on a 89-91, you would either need a block off plate of just stick in a cold start injector that isn't attach to anything. Other wise you will just have a huge vacuum leak.
