Gas Tank
Old Jul 21, 2003 | 05:18 AM
gonzo3613's Avatar
gonzo3613
1st Gear
Default Gas Tank
I have an 1985 second production vette. The car has been sitting for about six years. I have crank it up three times. It started right away. but now it wo'nt start. I have noticed alot of rust in the fuel....how do I remove the fuel tank? :lurk:
Old Jul 21, 2003 | 02:09 PM
sraft's Avatar
sraft
Default Re: Gas Tank (gonzo3613)
You can inspect the inside without removing the tank from the car (which is a pain). If you remove the fuel filler door, you'll be able to remove the fuel sending assemby. This leaves a 4"x6" opening that you can use to look into and inspect the tank. You can siphon the majority of the gas out, then sop up the rest with rags. I don't know about '85s, but my '94 has a plastic liner inside the tank - if you're lucky, maybe tank is OK and it's only the lines that are rusty.
