What the heck is this noise?
Once every 5 times or so, after the car has set overnight, I start it and right after it starts I hear this bizarre noise. It sounds like its coming from the passenger side of the car, but its really hard to pinpoint. The noise is difficult to describe, but for lack of a better description it sounds a bit like the noise a straw makes when you are trying to suck up the last liquid in a glass. Kind of a gurgling noise. Almost like a fuel line with air or something in it. It makes the noise for about 3 or 4 seconds and then it stops and all is well after that. Again, the car starts perfectly and runs great during this. It has happended with 3/4 of a tank of gas and with 1/4 of a tank, so the amount of fuel doesn't seem to be an issue. Anybody have any idea what this could be? :confused:
anyone else???
Jeff
This is a common problem on cold starts. Mine does this also.
Thanks!
Granted the ABS system is functioning normally, you will hear this sound everytime after start up, and it should sound the same each time.
Lastly ... the ABS is not related to the ASR system.
[Modified by SkunkCar, 4:43 AM 7/23/2003]
You won't hear the ABS pump do its cycle until you begin to move. Not sure of the exact speed, but I believe it's set to do its brief cycling at like 2 or 3 mph. So, if this sound is happening before you begin moving, then it is *not* the ABS pump (which, by the way, is in the compartment directly behind the driver's seat).
Then why does the ABS system pump whenever I hit a big enough hole on acceloration?
the gurgle is definately in the right side, dash. or at least that's where I hear it... and on mine, is is VERY inconsistant... I can go MONTHS without hearing it once... then it will do it 2 or 3 times... once, my AC programmer flashed.
Nope, that's not it. I know what that sounds like and that happens once the car in motion. This noise happens right after the car is started and before it is ever put in gear.
YES, that's EXACTLY what I'm talking about! Interesting that several of us are aware of the sound, but seems to be a couple of options on what it might be. It really is more of a "gurgle" than anything else. You can almost invision water running somewhere.
I have not read the theory of ASR in the factory manual (I should do so when I get home tonight -- the service manuals are *great* at covering that kind of stuff), but from looking at the mechanical end of things under the hood of my '96 car, it appears this system is designed to reduce throttle input when the rear tires lose traction. I'm thinking this because in looking at the ASR unit under the hood (driver side, above battery, about a foot in and back from the firewall -- black casing marked "ASR"), it has cables that run to throttle body ... why else, other than to control throttle input? :cool:
Now, as to why your ABS kicks in when you hit a hole under acceleration? Don't know, though I've heard of this happening before. In fact, an autocross buddy of mine who has a '91 coupe complained just the other day about how his ABS will kick in momentarily on occasion when he hits some rough sections on a road. This could probably be its own separate topic :D
This may sound way out in left field, but my garage refridgerator at home (you know, that place where all the beer is kept :cheers: ) makes a gurgling sound whenever the door has just been closed. I've always imagined it was freon (or whatever medium is being used to cool incoming air) that was making the gurgling sound ... I wonder if the same issue is at work in my garage as in your car? :crazy:
As far as this statement is concerned
The ASR system has control of three different things. Depending on conditions it can:
1. Reverse the throttle
2. Cut timing- limiting power there as well
3. APPLY REAR BRAKE/s to the wheel/s that are slipping. (it does this through the ABS system by computer.)
Or it can do all three or any combination of the above.
Thanks for the correction.
This may sound way out in left field, but my garage refridgerator at home (you know, that place where all the beer is kept :cheers: ) makes a gurgling sound whenever the door has just been closed. I've always imagined it was freon (or whatever medium is being used to cool incoming air) that was making the gurgling sound ... I wonder if the same issue is at work in my garage as in your car? :crazy: [/QUOTE]
The more we discuss this, the more I think in is probably AC related. I wonder if my habit of turning off the climate control just before parking it for the night is partially the culprit. Maybe not giving the system time to continue whatever process its in at the moment causes some sort of bubbles, or fluid flow, or something that needs to rectify itself on next startup. Next time it does it I'm going to see if I can quickly turn on the AC and "interrupt" the noise.
