F1R on L-98?
Old Jul 21, 2003 | 08:23 PM
AKS Racing's Avatar
AKS Racing
Default F1R on L-98?
I have not posted here in ages. Thought I would try to put some pics up of the latest progression on ol' yeller.
It is now tuned via FAST and I have adapted a new forced induction. Many of you have watched as I moved from the old P-600B to the D-1 on yellow, while setting up a D2R on red (must use aftermarket hood). Well it was time to upgrade yellow (why not???), so I stepped up to the F-1R. ATI makes it very clear that this will not fit under the hood, nor in any way within the confines of the wheelwell. It simply will not fit. Well, It will fit! All custom brackets, they have nothing for this application. It fits with less than 0.25" off the valvecover. It makes boost by 3000 rpm (remember I have huge heads/cam - AFR 220 and CC solid roller ~0.650") and will max the impellor at 6400 rpm (14.6 psi). The FAST system was definitly worthwhile (and required) for mounting something like this. And yes, I do still run the 6 rib, but in excess of 300 degrees wrap on the blower pulley. Hardly a hint of dust after several months.
Now let me see if I can get those pics uploaded. I am quite pleased with my dimensia.
Aaron
[Modified by AKS Racing, 7:24 PM 7/21/2003]
[Modified by AKS Racing, 7:37 PM 7/21/2003]
Old Jul 22, 2003 | 02:19 PM
vvv90's Avatar
vvv90
Default Re: F1R on L-98? (AKS Racing)
:cool: :cheers: :cool: :cool: :cheers:
Get us pics soon!
Old Jul 22, 2003 | 03:27 PM
krivera's Avatar
krivera
if you need help hosting them i am sure someone on here will help out :D
Old Jul 22, 2003 | 03:32 PM
black bart's Avatar
black bart
It is about time we heard from you. Glad to see that you got ole yellow running again. :seeya
Old Jul 22, 2003 | 08:03 PM
AKS Racing's Avatar
AKS Racing
Default Re: F1R on L-98? (black bart)
Ol yellow has been running throughout, just that I have been taking some time to do other things. I usually read the posts on here every couple of weeks, but finally pulled the password from email off my old computer and decided to log on.
BTW, did you wind up using an '89 hood prop on the passenger side to mount the D-1R, and are you still using the flat idler mounted on the alternator stud. I had seen other examples, and was familiar with the way that a D-1 mounts on an L-98 C-4, but did not like the fact that this way only allowed ~250 degrees of belt wrap. With the revision (seperate mount for a guided idler and the F-1R, I stepped from an 87.1" belt to a 95.6" belt. Everything for the blower mounting has a very specific order for installation, as all is very tight.
I also changed from the old sheetmetal ATI IC to a Spearco like the dimensions I had given you from my '89. At the same time I finally replaced the factory radiator with a Griffin (I did see a 15-20 degree drop in daytime TX temps).
How do you like the new D-1R? I have not had any issues with any of the ATI units that I have purchased. They work well for me. I keep getting hasseled about needing to take it to the track again, but the old timeslip from several iterations back still stands as my best (10.64 @ 138 mph). Have you had a chance to test yours at the track or dyno? I find it easier to take to the dyno these days, as there is a dyno close to the house, vs HRP (62 miles away).
I am having some issues with the scanner and hope to have the pics up soon. My son returns home today, so I'm sure he will be able to help (at 14 he runs circles around his dad on computer stuff). He also is getting quite proficient at tuning the FAST unit. Wonder wher that will lead.
Aaron
Old Jul 22, 2003 | 09:32 PM
black bart's Avatar
black bart
Aaron Shortly after I got mine running I fell while cutting the top out of a tree been layed up since spring. Just now starting to walk again. I still need to do some tuning I have it close but when I fell everything has been on hold. I used twin cylinders like the later vettes use did away with the prop. I bought the biggest core that spearco makes it is 3.5 X 15.6 X 20 inches but with the end tanks it is 26.5 inches. Kinda like putting 20lbs.in a 5lb. sack. I"M using a 8 rib belt no problems with it. I installed a grill in my car drove it last weekend ecm is set to turn the fans on at 185 but the tempature was 86 degrees and it was running 170 so fans didn't ever come on. When I had the ati intercooler it ran the fans all the time and still ran 200 I now have a gen.7 wideband really like it. :seeya
Old Jul 22, 2003 | 10:00 PM
AKS Racing's Avatar
AKS Racing
Sorry to hear about your misfortune. Rest up and get back at it. Need more people trying to do the unknown to help justify the path I take.
Aaron
To F1R on L-98?
