85 waterpump stud
Old Jul 23, 2003 | 06:46 PM
Hall1836's Avatar
Hall1836
Default 85 waterpump stud
While taking out the water pump broke lower stud on passenger side that also holds AC bracket. Unable to find anywhere, been discontinued by chevy. Anyone have a source for same? Stud is about 41/2 inches long. Also may as well change the heater hose that comes off the water pump. This is a hose that has three hose fittings, one that connects to the water pump and then the heater line, but there is also another coming off this hose to? Can this hose be gotten from Chevy? Thanks for your replies. As bad as this was at least it didn't break off in the block. The stud was rusted in the water pump and could oly get it out with saws-all and cold chisel.
Old Jul 23, 2003 | 07:47 PM
Bluevette85's Avatar
Bluevette85
Default Re: 85 waterpump stud (Hall1836)
I made my own fitting using a tee and heater hose or you can buy one from GM.
