Brake Booster....
Old Jul 23, 2003 | 09:16 PM
=Agent-Smith='s Avatar
=Agent-Smith=
Default Brake Booster....
Can anyone tell me how to check if my brake booster is busted, Thanks...
Old Jul 23, 2003 | 09:30 PM
SOVAIN1's Avatar
SOVAIN1
Default Re: Brake Booster.... (=Agent-Smith=)
I cant answer your question but I just wanted to tell you that I love your car!!!!!!!
Old Jul 23, 2003 | 09:32 PM
JF_AH_64's Avatar
JF_AH_64
Default Re: Brake Booster.... (SOVAIN1)
Is your pedal really hard, and do you here a hissing sound when you press on the brakes. Hard pedal-bad booster, soft pedal-master cylinder
Old Jul 23, 2003 | 10:07 PM
vader86's Avatar
vader86
Default Re: Brake Booster.... (JF_AH_64)
:iagree:
Old Jul 25, 2003 | 02:24 AM
R23HTC's Avatar
R23HTC
Default Re: Brake Booster.... (vader86)
:iagree:
:iagree:
Snake under dash, bad booster. Just replaced mine about a month ago. Had the hard pedal as well. About the same feeling you get if you're driving with your foot on the brake and you shut the key off.
Old Jul 25, 2003 | 03:53 AM
oldace84's Avatar
oldace84
St. Jude Donor '04 & '05
:iagree: :iagree: :iagree: :iagree:
Old Jul 25, 2003 | 04:05 AM
CentralCoaster's Avatar
CentralCoaster
From: San Diego , CA Double Yellow DirtBags 1985..Z51..6-speed
Default Re: Brake Booster.... (oldace84)
At worst, the pedal will be rock hard, you'll have no vacuum assist, it'll hiss, and the engine will stumble or even stall from the huge vacuum leak it opens up, and then you'll have no power steering as you plow into a street pole.
At best, the pedal will be rock hard, and you'll have partial assist, but it'll only get worse. Buy one with a lifetime warranty, and you won't have to worry about paying for one again.
If you buy a rebuilt, it's a crap-shoot. I've had horrible luck getting one that works, and so have others on here. :nonod:
To Brake Booster....
