$350 timing chains?
Old Jul 23, 2003 | 10:09 PM
SonnyinVA's Avatar
SonnyinVA
Default $350 timing chains?
i just got off the phone with jegs, and summit and they both say that the only timing chain they have available for my 96 is a $343 SINGLE roller cloyes set!!!
this seems outrageous to me... does anybody have any other alternatives or suggestions?
it seems like for that much $$ you ought to be able to get DOUBLE roller at least...
i've seen timing BELT kits that are in that price range (for GEN 1 tho)
jeez, how much is the stock chain?
Old Jul 23, 2003 | 10:21 PM
SPEED750's Avatar
SPEED750
Default Re: $350 timing chains? (SonnyinVA)
Keep looking!I'm pretty sure they make a double roller.They are outrageous though.I think you can buy just the chain for $39.I just saw this on the forum the other day.Also chevy makes a heavy duty set-up.Check with GMparts direct.I'm sorry I don't have a great answer. :rolleyes:
Old Jul 23, 2003 | 10:58 PM
BBA's Avatar
BBA
That just sounds too high. What does an LT4 chain set cost? (Should be good enough)
A friend of mine rebuilt his motor, he put a new opti/pump and timing chain/gear set on. He would have complained if it cost that much just for the chain set.
Old Jul 23, 2003 | 10:59 PM
Dougs 90's Avatar
Dougs 90
Default Re: $350 timing chains? (SPEED750)
http://www.superchevyperformance.com/engparts/timingchains/sbtimingchains/sbtimingchains.html
Take your pick!
Doug
Old Jul 23, 2003 | 11:18 PM
edsalinas's Avatar
edsalinas
St. Jude Contributor
Remember, there's alot of people out there with more dollars then cents. Keep shopping........
Old Jul 24, 2003 | 01:19 AM
Goody's Avatar
Goody
Default Re: $350 timing chains? (edsalinas)
You can get the LT4 Extreme Duty chain kit for that much and have money left over for some other stuff too. It is only about $30 or $40 more than a standard LT1/4 chain setup from Superior last time I checked...(Jeff was there).
Old Jul 24, 2003 | 02:01 AM
Ramrod92's Avatar
Ramrod92
Cruise-In II Veteran
Sonny, here is the problem. When you use the waterpump drive for the LT1/LT4 engine there is not enough room for a double roller timing chain. If you switch to an electric water pump you can us a double roller (I think I paid $80 from Summit for the Cloyes set.) Here is a picture of the GM extreme duty set which I had on my 396 before switching to the double roller. It was never run and I can make somebody a good deal on it. Drop me an email if your interested. :steering:
Old Jul 24, 2003 | 02:17 AM
Dan Parker '96's Avatar
Dan Parker '96
I bit the bullet and bought the Extreme Duty GM set. But try and price a set of rings for some stock '96 pistons. Good luck! Expect to spend $280-300. Nuts.
Old Jul 24, 2003 | 09:10 AM
SonnyinVA's Avatar
SonnyinVA
Default Re: $350 timing chains? (Ramrod92)
hey Ramrod,
i am using a meziere electric water pump so this cloyes set is exactly what i want. do you have a part number or anything like that?
thanks!!
Sonny
Old Jul 25, 2003 | 02:19 AM
R23HTC's Avatar
R23HTC
hey Ramrod,
thanks!!
Sonny
I don't have the part number but he's right on. Exact setup I run as well and I think the double roller was $85. Call Chris at Speed Demon. Link is in my sig or to your left. :D
Old Jul 25, 2003 | 07:52 AM
cprgmr's Avatar
cprgmr
hey Ramrod,
thanks!!
Sonny
The part number you're looking for for the Cloyes true double roller is 9-3145 (for use with Mez). :thumbs:
To $350 timing chains?
