IAC changing ?'s
Old Jul 23, 2003 | 11:27 PM
apollo30346's Avatar
apollo30346
Default IAC changing ?'s
I have a new one and thought I would change it, as I am having a idle issue when I turn the A/C on right after I start the car and sometimes it will stall...surge and such, and sometimes car will surge or idle high for a little and then drop to normal...the one in there is only about 1 1/2 years old, but I need the how to to change and what to do....I didn't know if I could just remove the old and put in the new and I'm done or what...If someone would clear this up please....
Thanks in advance
:confused:
Old Jul 23, 2003 | 11:41 PM
65Z01's Avatar
65Z01
Cruise-In II Veteran
Default Re: IAC changing ?'s (apollo30346)
On the L98 you need to clean the pintel bore under the TB and reset base idle to 450rpm (method on my site).
