Drive shaft removal ?
Old Jul 24, 2003 | 07:40 AM
Bluewasp's Avatar
Bluewasp
NoVa Events Coordinator
St. Jude Donor '14
Default Drive shaft removal ?
I need to remove the drive shaft (LT4) and wanted to know how to pull it out. I removed the u-joint straps, support beam, etc.. the shaft should pull right out? what about reinstall, is there anything I should know?
thanks
Old Jul 24, 2003 | 09:29 AM
ittlfly's Avatar
ittlfly
Default Re: Drive shaft removal ? (Bluewasp)
Its straight forward from there. Just push the driveline towards the trans to clear the yoke on the rear end and pull it out. Be sure that the trans is at least level to avoid a loss of fluid.
Old Jul 24, 2003 | 09:52 AM
scorp508's Avatar
scorp508
Make sure there are no burrs on the yoke in the area of the seal. When you push it back it could cut the seal and create leaks.
Old Jul 24, 2003 | 01:03 PM
CentralCoaster's Avatar
CentralCoaster
From: San Diego , CA Double Yellow DirtBags 1985..Z51..6-speed
Default Re: (scorp508)
You might as well mark the driveshaft and the position of the pinion, so that it is reinstalled the same way.
Some claim the drivetrain is balanced from the factory.
Old Jul 24, 2003 | 02:41 PM
scorp508's Avatar
scorp508
Mine has an itty bitty weight on the side of it, buts its been installed both ways and is smooth as silk.
To Drive shaft removal ?
