Base timing question on LT1
Old Jul 24, 2003 | 11:01 PM
Lone Ranger's Avatar
Lone Ranger
Default Base timing question on LT1
When the optispark is installed properly there is no base timing that is set, correct? Its a set value from there on that is adjustable only by the ECM, correct? So its not like the HEI distributors where its possible to inadvertently/mistakenly advance or retard the base timing off the factory default setting, right?
Old Jul 25, 2003 | 01:23 AM
STL94LT1's Avatar
STL94LT1
Default Re: Base timing question on LT1 (Lone Ranger)
Your correct, the opti will only go in one way. Unless you force it in wrong.
Old Jul 25, 2003 | 10:32 AM
Lone Ranger
Default Re: Base timing question on LT1 (STL94LT1)
:cool:
To Base timing question on LT1
