Hmmmm So That Explains the Dead Battey
Old Jul 25, 2003 | 12:15 PM
flyinace2000's Avatar
flyinace2000
St. Jude Contributor
Default Hmmmm So That Explains the Dead Battey
Well a month ago I had to replace the altenator and battery due to a electrical draw from the Dash. So in my sceptism i hooked up a volt meter to see if there was really a draw. Needless to say i removed the fuse and WAALAA. a current flow of 12 volts! to check my gear i looked at the current going through the crank fuse, 0 volts, as expected. So any ideas guys? How can i fix this or should i just knock off 300 bucks off the price to covers the next owners costs?
Old Jul 25, 2003 | 12:27 PM
88-L98-Z52's Avatar
88-L98-Z52
Default Re: Hmmmm So That Explains the Dead Battey (flyinace2000)
The presence of voltage is not the measurement to be concerned with... To measure current flow, you would have to measure AMPERAGE (current flow) by placing a meter IN SERIES (not across) the circuit you are measuring.
Old Jul 25, 2003 | 12:28 PM
don hall's Avatar
don hall
You measure the flow of current with an ammeter, not a voltmeter. I'm not sure if you are explaining the problem correctly.
Old Jul 25, 2003 | 01:47 PM
VetNutJim's Avatar
VetNutJim
Cruise-In I Veteran
Volts do not 'flow'.
Electrons 'flow' and the flow is measured in microamps,milliamps and amps and is called "current flow".
It's been a long time since engineering school but there is a definitive number of electrons flowing past a defined point that makes a whole "amp".
Voltage is just a potential like your engine running in neutral. No "flow".
What "FUSE" did you pull? A little more detail and some of these rocket scientist on here will tell you EXACTLY what's wrong.
Old Jul 25, 2003 | 04:28 PM
flyinace2000
Default Re: Hmmmm So That Explains the Dead Battey (VetNutJim)
::smacks head:: D'Oh
I pulled the 5amp LCD fuse. the VDC read 12v . I will borrow the amp meter from work late. And how would i do a proper test of amperage
Old Jul 25, 2003 | 05:18 PM
Bluevette85's Avatar
Bluevette85
Disconnect the positive battery cable. Connect the Amp meter between the battery cable and the battery terminal. Monitor the amp reading. Pull out one fuse at a time and if the amp reading drops alot, that is the circuit that is causing the problem.
Old Jul 25, 2003 | 05:44 PM
don hall's Avatar
don hall
.....And how would I do a proper test of amperage.....
No need to disconnect the battery cable. Use a "clamp-on" ammeter. My link explaining the clamp-on style ammeter didn't work. If you are interested, go to "google" and enter "clamp-on ammeter".
[Modified by Oldman, 2:52 PM 7/25/2003]
Old Jul 25, 2003 | 08:30 PM
Ramrod92's Avatar
Ramrod92
Cruise-In II Veteran
Default Re: Hmmmm So That Explains the Dead Battey (Oldman)
It will look something like this :steering:
Old Jul 25, 2003 | 08:54 PM
don hall's Avatar
don hall
Default Re: Hmmmm So That Explains the Dead Battey (Ramrod92)
Ramrod92, you are my hero! Thanks for the link............ :thumbs:
Old Jul 25, 2003 | 09:02 PM
LD85's Avatar
LD85
Being an ME I have to love you guys!
You know the saying
"you cant spell geek without EE"
Absolutely, no offense intended :nonod:
:hurray: :hurray: :hurray:
Old Jul 25, 2003 | 09:51 PM
don hall's Avatar
don hall
Default Re: Hmmmm So That Explains the Dead Battey (ld85)
...."you cant spell geek without EE"...Absolutely, no offense intended.....
OK, (Mr. id85)..even though you graciously suggest "no offense intended", I sensed a wry smirk on your face when you entered your post. As I recall, the ME discipline was offered as a two year home-study degree. :yesnod: :cheers:
Old Jul 25, 2003 | 09:52 PM
jfb's Avatar
jfb
If it is the dash circuit you suspect, then pull the fuse and put the ammeter probes on each fuse clip. The ammeter will then read the current flowing to the dash. The current out of the battery in C4's that are "off" should be less than 50 milliamps. My 87 measures 27 ma. If you put an ammeter in series with the positive battery cable, start the ammeter on its highest scale so the courtesy lights don't pin the ammeter. Or using clip leads to connect the ammeter probes to the battery and the positive cable lug, short the ammeter out by touching the ammeter probes together until the courtesy lights time out and then open the ammeter probes. This bypasses the meter and prevents harming the ammeter. Then you can start pulling fuses one at a time and watch the ammeter reading. A dramatic drop in current shows which circuit is drawing excess current and will need further investigation.
Be careful with your companies VOM, because if you have it set up as an ammeter and then try to measure battery voltage you will damage the ammeter. Ammeters are low resistance devices and a low resistance across a high current source (your car battery) will cause large current to flow and POOOOOOF, no ammeter! :eek:
Old Jul 25, 2003 | 11:06 PM
BBA's Avatar
BBA
Of course you are showing a picture of an AC only inductive pickup. (Batteries have DC curernt so that one wont work).
Of course, I have an AC/DC pickup that looks almost like that same one...except mine generates it's own inductive field the DC current interferes with. (It has a battery built in it just for that)
So, if you want to do it that way, expect to pay more for the AC/DC version of the pickup...or do it the old fashioned way and just wire the old fashioned VOM leads in series with the battery ground.
Old Jul 25, 2003 | 11:28 PM
Ramrod92's Avatar
Ramrod92
Default Re: Hmmmm So That Explains the Dead Battey (BBA)
Right you are Bill. Here is a AC/DC unit. :steering:
Old Jul 26, 2003 | 01:24 AM
LD85's Avatar
LD85
:leaving:
You caught me dead to rights! I still love you guys though! :seeya
Old Jul 28, 2003 | 10:00 AM
flyinace2000
ok guys i bought this thing at work today Ammete . This will work i hope.
Old Jul 28, 2003 | 11:59 AM
jfb's Avatar
jfb
The meter you bought can only measure A.C. amps with its clamp on jaws. D.C. amps are measured by placing the meter in series using the probes . The specs show 150 ma. d.c. . If the circuit has significantly more than 150 ma, you could damage the meter if it isn't fused on the 150 ma scale. The courtesy lights draw much more than 150 ma. Sears has a clamp on d.c. meter for $49. Now one problem d.c. clamp on meters have is they don't measure low values of current well. D.C. clamp on meters actually measure the magnetic field around a wire to tell the current and at low currents the earth's magnetic field causes a reading and it changes according to the position of the jaws.
[Modified by jfb, 11:00 AM 7/28/2003]
Old Jul 28, 2003 | 03:44 PM
flyinace2000
Default Re: Hmmmm So That Explains the Dead Battey (jfb)
thanks
To Hmmmm So That Explains the Dead Battey
