How much torque on bolts?
Jul 25, 2003 | 02:25 PM
This weekend I'll install heads and cam so I need some infos.
How much should I torque head bolts and in what order?
( I use FPP 1043 head gaskets )
On what bolts ( other than heads and intake ) is a must to use torque
wrench?
Jul 25, 2003 | 04:32 PM
Re: How much torque on bolts? (Sliding)
:confused:
Jul 26, 2003 | 02:54 AM
I found at ALLDATA that head bolts should be torqued at 68 ft.lb. ( 92 Nm ).
How accurate are data from ALLDATA, anybody else use info from their site?
[Modified by Sliding, 8:55 AM 7/26/2003]
Jul 26, 2003 | 05:35 PM
my 89 factory manual listing has them torqued to 67 lbs.ft (91 Nm). Basically the tightening sequence is to start in the middle and work your way out
<-----front of engine
---------------------------- edge fo rocker cover
13 5 2 10
17 9 1 6 14
--------------------------- edge of rocker cover
16 12 8 4 3 7 11 15
intake manifold runner to intake manifold plenum bolt 18 lbs.ft.
intake manifold runner to intake manifold bolt 18 lbs.ft.
intake manifold attaching bolt 35 lbs.ft.
exhaust manifold attaching bolt 35 lbs.ft.
valve rocker covers 80 lbs.in.
crankshaft pully center bolt 70 lbs.ft.
crankshaft pulley outer bolt 32 lbs.ft.
crankshaft torsional damper bolt 60 lbs.ft.
engine front cover bolt 80 lbs.in.
camshaft gear bolt 20 lbs.ft.
rocker arm studs 50 lbs.ft.
oil pan bolts 16 lbs.ft.
Jul 29, 2003 | 01:48 PM
Re: How much torque on bolts? (DaveD)
Thanks DaveD.
Looks like ALLDATA info's are O.K.
:cheers:
Jul 29, 2003 | 01:57 PM
Are you using new OEM bolts or new ARP bolts? Are you using motor oil, thread sealer, or assembly lube on the threads?
