ABS not active in a while
Old Jul 25, 2003 | 02:38 PM
9T4YY1's Avatar
9T4YY1
Default ABS not active in a while
I recently upgraded my '94 to the J55 setup. Since then I've not activated the ABS system. It does make the noise when first started up and the light lights up and goes off on the DIC so I assume it's working. My question is, could the increased braking of the J55s make it less likely to activate the abs system ?
Old Jul 25, 2003 | 10:00 PM
jfb's Avatar
jfb
Default Re: ABS not active in a while (9T4YY1)
If the ABS is active, then when one or more wheel rotates more slowly than the others when braking, the ABS will pulse the brakes.
