change oil light
Old Jul 25, 2003 | 08:04 PM
davds96's Avatar
davds96
Default change oil light
my 96 change oil light just came on today I have been changing the oil the last year is there something I need to reset when I do the oil only has about 700 miles on the last change
thanks
David
Old Jul 25, 2003 | 08:12 PM
sumoboy's Avatar
sumoboy
Default Re: change oil light (davds96)
1) turn key on , do not start
2) press Eng/Met button , within 5 sec, press again
3) press Gauges button ,light will flash, hold until flashing stops, change oil light will go out and be reset
on a 96
1. Turn ignition "ON" but do not start engine.
2. Press the "ENG/MET" Button and release, then, within 5 seconds, press it again.
3. Within 5 seconds of step 2, press and hold the "GAUGES" button. While the button is held,
the "CHANGE OIL" indicator will flash.
4. Continue holding the "GAUGES' button until the "CHANGE OIL" indicator stops flashing and goes out, indicating successful completion of the reset cycle. If id does not successfully reset, turn the ignition "OFF" and repeat the procedure from step 1.
_______
[Modified by sumoboy, 8:18 PM 7/25/2003]
Old Jul 26, 2003 | 07:46 AM
davds96's Avatar
davds96
Default Re: change oil light (sumoboy)
thank you for the info
David
To change oil light
