Timing 85 TPI + est location
Old Jul 28, 2003 | 12:36 PM
ROCKY85's Avatar
ROCKY85
Default Timing 85 TPI + est location
Heres the problem the veci label is gone and I need the timing setting along est wire location. Thanks for the help
Old Jul 28, 2003 | 12:37 PM
Bluevette85's Avatar
Bluevette85
Default Re: Timing 85 TPI + est location (ROCKY85)
Timing is 6 deg and est connector in between the brake booster and wiper motor.
Old Jul 28, 2003 | 12:51 PM
TheCorvetteKid's Avatar
TheCorvetteKid
Default Re: Timing 85 TPI + est location (Bluevette85)
:iagree:
The EST connector is a 2.5"-3" long black single-terminal connector that breaks out of the left hand side main wire harness loom and has a tan and black wire going into it.
Don't forget to disconnect the battery for at least 10 seconds to clear the error code that will be stored in the ECM after you set your timing.
Good luck.
[Modified by TheCorvetteKid, 11:52 AM 7/28/2003]
To Timing 85 TPI + est location
