Need procedure for replacing shocks on my 89.
Old Jul 28, 2003 | 06:36 PM
Black'69's Avatar
Black'69
Default Need procedure for replacing shocks on my 89.
Hey guys,
Does anyone have a good procedure or any tips on replacing the shocks on an 89? Looks like I'm going with the Blistein- Z51. Is this something that is easy to do? I've done it on other cars, just a little light experience with C4.
Thanks in advance,
Christ
Old Jul 28, 2003 | 08:52 PM
Iroc's Avatar
Iroc
Default Re: Need procedure for replacing shocks on my 89. (Black'69)
Ive got a set of 4 bilsteins, only got the rear 2 on so far.
When you take out the old rear shock, jack up the bottom of the shock to let the weight off else you might mess up the threads on the top bolt. Same for installing to help get the top bolt in.
Make sure you have a large enough end wrench for holding the lower rear shock mounting stud while you tighten the nut.
On the front, you might need a specialty socket for the top shock stud. Also check to make sure you can get that socket on it and keep the stud from turning while you remove the nut.
I thought i read something that said you might need to compress the front shocks a little to get them in, might be good to have a extra hand during the front install.
Good luck
Old Jul 28, 2003 | 08:57 PM
atotalnincompoop's Avatar
atotalnincompoop
no special instructions needed, just unbolt the old ones and bolt the new ones on, simple as that :yesnod: :cheers:
Old Jul 29, 2003 | 12:43 AM
Black'69's Avatar
Black'69
Default Re: Need procedure for replacing shocks on my 89. (atotalnincompoop)
Yeah, it looked pretty strait forward, just making sure there wasn't any hidden issues. Thanks guys :thumbs:
To Need procedure for replacing shocks on my 89.
