Chevy Ram Jet
Old Jul 28, 2003 | 11:44 PM
Dougs 90's Avatar
Dougs 90
Default Chevy Ram Jet
How tall is this compared to the TPI? Anybody know?
Old Jul 29, 2003 | 08:38 AM
cbernhardt's Avatar
cbernhardt
C1 of Year Finalist (track prepared) 2019
Default Re: Chevy Ram Jet (Dougs 90)
If you are referring to the Ram Jet 350, the height from the flat part of the block (China wall) to the top of the air plenum is 9.5". The top of the plenum is parallel to the block.
The 502 version of the Ram Jet is about 11.5". I have the exact measurement somewhere. If that is the one you need, let me know.
Charles
Old Jul 29, 2003 | 01:52 PM
Dougs 90's Avatar
Dougs 90
Default Re: Chevy Ram Jet (cbernhardt)
Ram Jet 350 is what I need! So isn't the TPI like 9"? I may be on to something here!! Anybody know exactly how much clearance is required to fit under the hood? Trying to see if this will work.
Old Jul 29, 2003 | 02:31 PM
cbernhardt's Avatar
cbernhardt
Doug:
A quick way to measure is to place the vehicle on a relatively level concrete floor then, with the hood closed, use something like a carpenter's roll up tape and measure from the floor to the bottom of the hood near the front of the block (if you can find a space up through all the accessories and hoses). Then open the hood and measure from the flat part of the block to the floor. If you have at least 9.5", the Ram Jet 350 should fit. Might do well to add an extra 1/4" or so for any movement just to be on the safe side.
I guess you know that the Ram Jets are not "legal" for use in vehicles that are required to pass an emissions test (anything later than a '74 model in NC). Also the Ram Jets are not user programmable like the LS1.
Charles
[Modified by cbernhardt, 2:34 PM 7/29/2003]
Old Jul 29, 2003 | 11:41 PM
Dougs 90's Avatar
Dougs 90
Wont fit, too tall.... :cry :(
To Chevy Ram Jet
