Hydra-rev kits -- anyone using one?
Old Jul 28, 2003 | 11:56 PM
davepl's Avatar
davepl
Default Hydra-rev kits -- anyone using one?
AFR (the head manufacturer) makes a HydraRev kit that places extra downforce on the hydraulic lifter body (since high spring pressures would just collapse the hydraulic lifter).
http://www.airflowresearch.com/pages/hydra_rev.htm
This all sounds like a great idea on paper if you want to try to rev to 6500+ but does anyone have experience with one? Looking for dis/recommenations!
Thanks,
Dave
Old Jul 29, 2003 | 01:05 AM
BAM92's Avatar
BAM92
Default Re: Hydra-rev kits -- anyone using one? (DAVE396LT1)
I have seen them on alot of cars over at MTI. Usually they were strokers built to high rev.
Old Jul 29, 2003 | 01:09 AM
Ramanstud's Avatar
Ramanstud
:cool:
I wish I had the need to use one. :D
Old Jul 29, 2003 | 09:14 AM
black bart's Avatar
black bart
You should do a search this has come up several times in the past 6 months. However some who posted about them had no idea how they worked that was obvious from their post. I have had them in my current engine for the past four years. When I build another engine they will be in it also. :yesnod:
Old Jul 29, 2003 | 09:36 AM
LT4POWR's Avatar
LT4POWR
I've got one and my car pulls hard to 7,000 rpm!!! :eek: However they should not be used as a bandaid for inadequate valvesprings.
Old Jul 29, 2003 | 10:31 AM
4DRSS's Avatar
4DRSS
Default Re: Hydra-rev kits -- anyone using one? (LT4POWR)
I use one on my car. My stock bottom end LT1 pulls to 7,200 RPM, the PCM cut off, with no issues.
The main advantage I have found with the hydra rev kit is keeping power after your power peak. My car makes peak power at 6,600 RPM, but at 7,200 RPM I am only down 5 RWHP. Without the hydra rev I am sure I would be down at least 15-20 RWHP at 7,200 RPM. Very trick piece, no need to worry about valve float with one.
[Modified by 4DRSS, 9:32 AM 7/29/2003]
Old Jul 29, 2003 | 11:36 AM
Ramrod92's Avatar
Ramrod92
Cruise-In II Veteran
Default Re: Hydra-rev kits -- anyone using one? (4DRSS)
Andrew, have you noticed any drawbacks? (loss in lower rpm range) :steering:
Old Jul 29, 2003 | 12:31 PM
davepl's Avatar
davepl
I'm using AFR's #8015 springs which are 145lbs seat, 355 open. I don't think you can run much more spring pressure than that without collapsing the hydraulic lifters.
Old Jul 29, 2003 | 03:00 PM
bogus's Avatar
bogus
Default Re: Hydra-rev kits -- anyone using one? (Ramrod92)
(not the same andrew) I would think not. essentially, its a valve spring helper, and won't have any effect air flow or valve lift...
Old Jul 29, 2003 | 03:55 PM
4DRSS's Avatar
4DRSS
Default Re: Hydra-rev kits -- anyone using one? (bogus)
No there are no drawbacks to using this kit, well expect maybe a little more noise from the valvetrain.
Old Jul 29, 2003 | 04:33 PM
LT4POWR's Avatar
LT4POWR
The only other drawbacks I can think of might be a couple of extra pounds, about $200 less dollars, and the PITA to install. Beware of flying springs!!!
If someone what to see/post pics, I have some before/during/after the install.
Old Jul 29, 2003 | 05:26 PM
davepl's Avatar
davepl
I'd love to see pics, post away!
Old Jul 29, 2003 | 05:53 PM
LT4POWR's Avatar
LT4POWR
Could I e-mail the pics to someone and have them post em? I'm kinda technologically challenged...
Old Jul 30, 2003 | 06:48 AM
vettmanlt4's Avatar
vettmanlt4
LT4POWER
PITA is mild. I have been trying to install for the last 2 nites.
Did you buy the AFR install tool?
Any install tips from anybody would be appreciate!
[Modified by vettmanlt4, 5:56 AM 7/30/2003]
Old Jul 31, 2003 | 01:20 PM
LT4POWR's Avatar
LT4POWR
I'm running stock lifters, the Rev Kit, and CompCams #985-16 springs, 140lbs seat, 340 open. I don't think valve float is going problem, but we'll see at the dyno next week..
Old Jul 31, 2003 | 01:22 PM
LT4POWR's Avatar
LT4POWR
Help Forum :thumbs:
Old Jul 31, 2003 | 01:27 PM
LT4POWR's Avatar
LT4POWR
Default Re: Hydra-rev kits -- anyone using one? (vettmanlt4)
LT4POWER
Get the install tool and some eye protection. Set valve lash according to the instructions. I installed it with the heads already on, but I've read where you can do it a different way. Compress the springs at the second to the last coil. Good Luck
To Hydra-rev kits -- anyone using one?
