Inflatable restraint message
Old Jul 30, 2003 | 09:22 PM
BJP's Avatar
BJP
5th Gear
Default Inflatable restraint message
My 90 coupe is showing inflatable restraint warning that won't go off. There is no problem that I'm aware of. Anyone run into this before? Thanks
Old Jul 30, 2003 | 09:51 PM
RichS's Avatar
RichS
Default Re: Inflatable restraint message (BJP)
Welcome to the forum. :cheers:
Use the info listed here: https://www.corvetteforum.com/techti...D=46&TopicID=2
I just reset the light on a 90 Vert I was working on using this tech tip.
Old Jul 30, 2003 | 09:55 PM
Dr. Evil's Avatar
Dr. Evil
CI 1-2-3-4-5-6-7-8 Veteran
CI-IV AutoX Champ
CI-IV Burnout Champ
St. Jude Donor '07-'10
Default Re: Inflatable restraint message (RichS)
Allmost all the 1990 models have this problem. Its a 1 year wonder :rolleyes: Use the tech tip and take your time. It works. I did it to my 90 coupe. One other thing about the 90 models. The tachometer is usually off by several hundred rpm and in many cases by as much as 2000 or even 2500rpm. Its not off on a linear basis either. At 2k actual rpms it may read 2500, at 4k actual rpms it may read 5000rpms and so on. Mine said 6000rpms I was really only turning 4000rpms. There is no fix that I know of for this problem. I used an aftermarket tach with shiftlight.
Old Aug 1, 2003 | 08:24 AM
BJP's Avatar
BJP
5th Gear
Thanks guys--it doesn't sound simple but I think I can do it. I'll have to try it when I get back from vacation. Thanks again.
To Inflatable restraint message
