engine temp. gauge sensor
Old Aug 1, 2003 | 08:09 AM
Joep's Avatar
Joep
Navigator
Default engine temp. gauge sensor
Hi guys, my engine temp. gauge (anolog) does not work. and I found a small sensor hanging on the pass. side of the engine. The sensor looks all distorted. Could this the engine temp. sensor and if it is where does it connect . Also if anyone has a pic. of this sensor please include it (just to make sure we are talking about the same thing)
Old Aug 1, 2003 | 08:28 AM
jfb's Avatar
jfb
Default Re: engine temp. gauge sensor (Joep)
On the block between cylinders 6 and 8, you will see a bolt with an electrical spade connector on it. This is the temperature sender for the temperature gauge. Your loose wire should plug onto the spade connector.
Old Aug 1, 2003 | 08:47 AM
Joep's Avatar
Joep
Navigator
Default Re: engine temp. gauge sensor (jfb)
The sensor was connected to the wire and all I can see is a hole about 1/2 in. in dim. There is no bolt. This is an lt1 (1992)
Old Aug 1, 2003 | 09:05 AM
Joep's Avatar
Joep
Navigator
I found the bolt the plastic part fell off. Is there an easy way of take this off?
Old Aug 1, 2003 | 09:42 AM
jfb's Avatar
jfb
The sensor screws into the block. You will have to lower the antifreeze level below the sensor and unscrew the sensor with a socket wrench and install a new sensor.
Old Aug 1, 2003 | 10:45 AM
Joep's Avatar
Joep
Navigator
thanks I just finished the install. A little tight, but mission accomplished. Thanks again
To engine temp. gauge sensor
