Old Mar 2, 2015, 08:15 PM
How-Tos on this Topic
Last edit by: IB Advertising
See related guides and technical advice from our community experts:
Browse all: Engine and Powertrain
Print Wikipost
Throttle Body Spacer Plate
Old Aug 1, 2003 | 02:11 PM
CREWZIN's Avatar
CREWZIN
Default Throttle Body Spacer Plate
Something new at Mid America? They have one for my PT Cruiser and almost everyone says it's junk. How bout in the Vette?
You're just an inch away from horsepower gains of up to 20, along with dramatically increased torque and improved fuel economy! By extending your 1985-91 Corvette's throttle body injection unit 1", the Power Tower Spacer Plate's unique Helix spiral flow design improves fuel atomization, which results in more complete combustion. Bolt-on unit installs between the throttle body and intake manifold in less than 30 minutes. Complete instructions and hardware included.
[Modified by CREWZIN, 2:12 PM 8/1/2003]
Old Aug 1, 2003 | 02:21 PM
Topless87's Avatar
Topless87
Default Re: Throttle Body Spacer Plate (CREWZIN)
:rolleyes:
Wasn't there a t-shirt around that said "I bought this t-shirt and gained 10 HorsePower!"
Old Aug 1, 2003 | 02:42 PM
vader86's Avatar
vader86
Do you really think that adding an inch to the TB is going to give you 20hp? What about 2", wouldnt that give you 40hp?
you know it doesnt work, at best it would give 1-2ft-lbs of torque, and a similar LOSS in Hp.
Old Aug 1, 2003 | 02:46 PM
ski_dwn_it's Avatar
0ski_dwn_it
Former Vendor
yeah that might work with fuel atomization IF THERE WAS ANY FUEL EVEN CROSSING OVER THE FREAKIN P.O.S.
I need to just start looking for ideas like this to make a fortune so I can just tinker with my car all day. Sad thing is, it wouldn't be had to probably make a million dollars doing it. Just look at the tornado :rofl:
I could spend 8 thousand dollars on some 350+ CFM ported heads that I could replace my current heads with, put a tornado type device in the plenum, then run low 10s and all day long, and market the device. instant millionaire :D :jester :leaving:
Old Aug 1, 2003 | 03:21 PM
tobijohn's Avatar
tobijohn
Bench Racer
St. Jude '03 thru 14,'25
Does anyone know why these manufacturers can get away with making these kinds of claims? Isn't that fraud?
Old Aug 1, 2003 | 03:30 PM
vvv90's Avatar
vvv90
Default Re: Throttle Body Spacer Plate (ski_dwn_it)
:rofl: :rofl: :lolg: :lolg: :lolg:
OH MY GOD! How can this help fuel atomization on an MPI car in any way possible? :confused:
Old Aug 1, 2003 | 03:43 PM
ski_dwn_it's Avatar
0ski_dwn_it
Former Vendor
Default Re: Throttle Body Spacer Plate (vvv90)
Because 90% of the people out there are like: " What is MPI?"
And they have no friggin clue how the gas gets from the rear of the car to the front. Its a magical experience they take for granted everytime they hit the key to start it. :D :crazy: :banghead:
Old Aug 1, 2003 | 04:12 PM
LaVidaLoca's Avatar
LaVidaLoca
:skep:
Funny that it states that it is for 85-91 and says it improves fuel atomization and could only have any possible effect like that on an 84! It would be funny if it were not so much :bs
Best rule of thumb: if it's cheap and easy and it promises a bunch of HP it's probably not true. Serious HP = serious $.
Too bad Consumer Reports isn't interested in Corvette performance equipment. :)
Old Aug 1, 2003 | 07:01 PM
tkrussell's Avatar
tkrussell
Default Re: Throttle Body Spacer Plate (LaVidaLoca)
P. T. Barnum said it best: "There's a sucker born every minute!"
My personal favorite is the Slick 50 ad that promises so much reduction in friction that you can run the engine without oil!
Old Aug 1, 2003 | 10:01 PM
TA's Avatar
TA
SSSSSSSnake oil :yesnod:
Old Aug 1, 2003 | 10:10 PM
oldace84's Avatar
oldace84
St. Jude Donor '04 & '05
Default Re: Throttle Body Spacer Plate (TA)
If it walks like a duck, and talks like a duck, then it is a duck.
:withstupid: :withstupid: :withstupid:
Old Aug 1, 2003 | 11:23 PM
FX GS's Avatar
FX GS
Default Re: Throttle Body Spacer Plate (oldace84)
If you believe all the products advertised in the catalogs, for about $200 you can add 300 or so hp!! :eek:
Old Aug 4, 2003 | 06:10 AM
CentralCoaster's Avatar
CentralCoaster
From: San Diego , CA Double Yellow DirtBags 1985..Z51..6-speed
Default Re: Throttle Body Spacer Plate (FX GS)
It will restrict air flow, increase noise, increase plenum vacuum, and most of all,
It will decrease Horsepower and Torque at ALL RPMS.
Putting your hand over the air filter does the same thing. The plenum length is NOT a design parameter for the tuned intake's performance.
:bs :bs :bs
Old Aug 4, 2003 | 07:50 AM
Mr. Magoo's Avatar
Mr. Magoo
From: Damn taxes! Pimpin' Ain't Easy in Massachusetts
2018 C4 of Year Finalist
St. Jude Donor '03-'04-'08-'09
I laugh everytime I see one of these POS things. :lol:
Old Aug 4, 2003 | 09:02 AM
88-L98-Z52's Avatar
88-L98-Z52
Default Re: Throttle Body Spacer Plate (tkrussell)
HEY!!! Now there is something EVERYONE should do!!!... Just pick up one of those 5 quart jugs of oil and notice how heavy 5 quarts of oil is!!!... Why, just the weight savings from not having to waste the horsepower needed to move that weight around would probably knock off a couple of seconds in the quarter mile and increase the Miles Per Gallon by at least 5 MPG or more. Plus, since you would no longer need other oil related components, like oil filters and oli pans and sending units and oil pumps, removing all those extra weighty components too would probably double or triple the SOTP performance gains!!!
Plus... ever notice how hot oil gets?!?!... Well... removing all that heat from the engine would mean we would no longer need water to cool it!!! Whoo Hoo!!... Another 5 gallons of weight that could be eliminated while adding another 50 or so HP!!!
Think I'm gonna get busy writing a new TECH TIP to detail the procedure!!
Old Aug 4, 2003 | 10:23 AM
-=Jeff=-'s Avatar
-=Jeff=-
Default Re: Throttle Body Spacer Plate (88-L98-Z52)
It would be a good piece to drillout on each side to add some nitrous jets :D
Old Aug 4, 2003 | 10:38 AM
Mr. Magoo's Avatar
Mr. Magoo
Default Re: Throttle Body Spacer Plate (-=Jeff=-)
Hmmmmmmmmmmmmmmmmm...................... .....
Old Aug 4, 2003 | 04:43 PM
CentralCoaster
Default Re: Throttle Body Spacer Plate (Mr. Magoo)
Then you could send em a letter, and show em how theyre spacer plate added 100 hp to your vette.
Maybe then the'll change the horsepower claims! lol
To Throttle Body Spacer Plate
