First start with new cam - need help!
:blueangel:
take some pics. :)
Now when #1 is on firing position, timing mark on 0*, rotor is
almost perfectly lined up with #1 plug on cap.
Isn't this he way that it should be?
then I'll be sure when #1 is on firing.
BTW I borrowed timing light and timing is 53* ATDC :eek: :eek: :eek:
Could the engine run like that???
There is probably something wrong with this timing light.
BTW, how did you determine it was 53 degrees atdc? Do you have a fully degrees balancer?
[Modified by jimtreber, 10:13 PM 8/3/2003]
[Modified by jimtreber, 10:15 PM 8/3/2003]
If you have really bad valve noise then that could hurt you too because the gap is not right and you may want to look at that too, it sounds like you have the valves too lose.
And since you had the intake off you may have a intake leak too that would make your engine run badly tooI would look into that.
Keep us posted.
PS Scorp508 is right you may want to check if you have the firing order is right.
Jay
[Modified by MrJay, 7:30 PM 8/3/2003]
I'm 100% sure that wires on distributor and plugs are on right position.
timing a little bit before I disassembled engine and it was straight at 6*BTDC.
I have tried to install distributor all over again and I ended up
with same situation. The engine starts without problem but it's noisy
and it feels like it's misfiring. Throttle response is not good.
I'm begining to wonder if cam is in right position. I'm sure that it was
installed corectly ( crank 12, cam 6 o'clock ) but maybe the cam gear
(for distributor) wasn't installed correctly when it came from LPE.
Could that cause this kind of problems?
I'm also in position with installed cam, ported heads, headers but
with STOCK CHIP. I know that this can cause engine not to run
very good, but can it affect on setting base timing?
And thank you all for trying so much to help me.
I think that I woul be in deep s*** without your help right now.
I'll try to see if I have any error codes stored in ECM.
Talk to you later.
Bit of head scratching and I realised my new timing light was of the dial back variety, and it needed zeroing. The timing was actually only 2 deg out! :banghead:
light soon then I'll be sure.
Anyway, I checked ECM and I have error code:
42 Electronic Spark Timing Circuit (EST)
I believe that this code came with SES light when I disconnected
advance wire while trying to adjust timing.
But why is this error still stored? I don't have SES light now but when I
enter diagnostic mode it reads code 42.
how the engine is running.
I got it to work a little bit better and went to test drive.
It's better now but still there is not enough power and some misfiring.
I tried the timing light that I used on my frindes car and it also
reads some crazy numbers so it looks that there is something wrong with it.
On Thursday I'll get reliable timing light and then I'll make sure that
timing will be right.
I'll keep you posted with results.
I did everythin right the first time but the problem was
in timing light ( it was good only for 4 & 6 cylinder engines ).
Now, the timing is set to 6* BTDC. The valves are still a little bit noisier
than normal but I'm really begining to think that maybe it's normal
because of more agressive cam and harder valve springs.
Anyway I'll try to adjust valves one more time on Saturday and
I'll do it with engine running to be sure.
Next week I'll have to insure car and then I'll make some test drives to see
what did I gain but I'll start new topic about that.
Thank you for all your help.
:chevy :chevy :chevy
