Rear Brakes
Old Aug 2, 2003 | 12:44 AM
rsafier's Avatar
rsafier
Default Rear Brakes
Okay, need to replace the rear pads on my 85. On one did the metal backing seperated from the pad!
I never have messed with the brakes before. Looking in my Haynes manual it says the bolt holding the caliper is self-locking and needs to be replaced on reinstall. Is this true? If so does anybody know the specs on that bolt so I could get replacements before I switch pads?
Old Aug 2, 2003 | 01:25 AM
oldace84's Avatar
oldace84
St. Jude Donor '04 & '05
Default Re: Rear Brakes (rsafier)
I know you need them now. But why don't you go for the info on VBP (vette brakes & products).
http://www.VBandP.com
This catalog is free and gives so much info, it will surprise you.
If you can wait, order the catalog. Or go to the web site.
tony
:chevy :chevy :chevy :chevy
Old Aug 2, 2003 | 02:05 AM
rsafier's Avatar
rsafier
Default Re: Rear Brakes (oldace84)
Will do, but in the meantime I have a set of pads :)
Old Aug 2, 2003 | 09:59 AM
ittlfly's Avatar
ittlfly
Usually the "self locking" bolt is nothing more than some Lock Tight on the threads. You can buy new ones from Chevy @ about $5. per bolt or put some of the stuff on the old bolts and reuse them.
Old Aug 2, 2003 | 10:14 AM
Mr Mojo's Avatar
Mr Mojo
Elite Torch Red Member
Cental/South NJ Events Coordinator
CI 1-2-3-4-5-6-7-8-9-10-11-12 Vet
CI-II Burnout & Drag Champ
St. Jude Donor '03-'04-'05-'06-'07
Default Re: Rear Brakes (ittlfly)
I reused mine, no problems yet.
To Rear Brakes
