clutch leak???
Old Aug 2, 2003 | 10:12 AM
chrply's Avatar
chrply
Default clutch leak???
My clutch pedal started going down so i checked the fluid, it was empty...I filled it up, got my clutch back, but see no signs of leakage anywheres...is that normal????? :confused:
Old Aug 2, 2003 | 10:14 AM
Mr Mojo's Avatar
Mr Mojo
Elite Torch Red Member
Cental/South NJ Events Coordinator
CI 1-2-3-4-5-6-7-8-9-10-11-12 Vet
CI-II Burnout & Drag Champ
St. Jude Donor '03-'04-'05-'06-'07
Default Re: clutch leak??? (chrply)
It has happened on my '95 and my truck.
Of course GM says that just refilling doesn't solve the problem, but I only have to do it every 9 months or so, so I can live with it.
Old Aug 2, 2003 | 11:18 AM
Powerdrive's Avatar
Powerdrive
Hey ... You will not see any outward signs of leakage. All the fluid for my clutch leaked through the firewall and inside the cockpit.. Check your floor, drivers side up in the upper corner (where clutch goes thru wall) for leakage. you gotta get under the carpet and foam to really tell. Good luck..really not that bad to replace..... :flag :chevy
To clutch leak???
