parking brake adjustment
Old Aug 2, 2003 | 01:40 PM
JF_AH_64's Avatar
JF_AH_64
Default parking brake adjustment
My parking brake isn't holding anymore, I tried pulling the parking brake 3 consecutive times to adjust it, but with no luck. Is there some way to adjust the brake at the rear wheel. Thanks
Old Aug 2, 2003 | 05:06 PM
C4396roadster's Avatar
C4396roadster
Default Re: parking brake adjustment (JF_AH_64)
if I remember correctly its controlled by the brake handle assembly itself,self setting I changed mine for $60 from http://www.TLD.com
Old Aug 3, 2003 | 02:48 PM
JF_AH_64's Avatar
JF_AH_64
Default Re: parking brake adjustment (C4396roadster)
So my only course of action is to buy a new parking brake assembly? :confused:
Old Aug 3, 2003 | 05:11 PM
ittlfly's Avatar
ittlfly
I think your 94 is the same as my 92. Be sure the pads are OK. Will the brake handle rachet up? Check that the cable is still attached to the arm @ both rear calipers (next to the big spring.) If you think that all the above is operating ok, then there is a proceedure for adjusting the parking brake in the Helms. It has to be done at the calipers themselves with a smalll allen wrench.
To parking brake adjustment
