1986 4+3 - How can I lock out 1st OD?
I am looking for a quick fix to eliminate the OD function in 1st gear...I have spilled far too many coffees....I still want the unit to perfrom as intended in 2nd, 3rd and 4th...so I don't want a switch-able solution such as the one in the tech tips section.
Location: San Diego , CA Double Yellow DirtBags 1985..Z51..6-speed
Re: 1986 4+3 - How can I lock out 1st OD? (redvette1986)
Overdrive shouldn't engage in first gear, if the first gear switch works.
Actually, it does in one case, when you're decellerating from 2nd+OD. I think this feature is actually to prevent you from spilling coffee!
Re: 1986 4+3 - How can I lock out 1st OD? (CentralCoaster)
1986 is the only year that does not have a 1st gear switch on the side of the transmission. The only time you "shhould" see OD in 1st is when downshifting while OD was already engaged. It should then go out under any throttle or if you get below 4mph.
Re: 1986 4+3 - How can I lock out 1st OD? (scorp508)
[Modified by redvette1986, 4:01 PM 8/4/2003]
