My right headlight is struggling.....
Old Aug 4, 2003 | 12:28 PM
VET 350's Avatar
VET 350
Default My right headlight is struggling.....
Whenever I put my headlights on, the right headlight struggles to go up.
Sometimes I have to try 2 or 3 times before it goes up.
Is there something I could "grease" it with to prevent farther damage or to make it go up better? :confused:
Thanks,
VET 350
Old Aug 4, 2003 | 05:26 PM
bstirn's Avatar
bstirn
Default Re: My right headlight is struggling..... (VET 350)
My 92 right side is acting up also. ill keep an out on this post :(
Old Aug 4, 2003 | 06:07 PM
red LT-4's Avatar
red LT-4
Check out the section on tech tips for this problem.
1989redvette's Avatar
1989redvette
sounds like it's time for a bushing kit to be installed in the headlight motors..theya re like 10 bucks for both sides through ecklers and such...worked wonders on my 89 :cheers:
Old Aug 4, 2003 | 07:38 PM
VQT88Vette's Avatar
VQT88Vette
Default Re: My right headlight is struggling..... (1989redvette)
:yesnod: :yesnod:
Old Aug 4, 2003 | 09:47 PM
TPFKATK's Avatar
TPFKATK
Default Re: My right headlight is struggling..... (VQT88Vette)
Could be the brushes. That was my problem. Here is the thread: http://forums.corvetteforum.com/zerothread?id=561308
Good luck.
Harold
Old Aug 5, 2003 | 12:23 AM
BAM92's Avatar
BAM92
Default Re: My right headlight is struggling..... (TPFKATK)
My 89 and 92 had that problem. Bushings. 3 bucks a side through the corvette catalogs. Might as well do both at same time. Not that hard.
Old Aug 6, 2003 | 05:07 PM
VET 350's Avatar
VET 350
Default Re: My right headlight is struggling..... (BAM92)
Would it hurt to ignore the problem and just keep using it as long as it comes up for me? I guess what I'm trying to ask is, Am I damaging anything if I keep on turning them off and on until they both are up?
Old Aug 6, 2003 | 05:40 PM
TPFKATK's Avatar
TPFKATK
IF your problem is brushes then yes it will cause further damage. The problem is poor electrical contact which generates HEAT in the brushes and plastic brush housings. They will melt and then you have to replace the housings or whole motor instead of just cleaning everything up. In my case the housing had just started to melt which prevented the brushes from firmly contacting the armature. I was able to clean them up with fine sandpaper and they are still working fine.
Good luck.
Harold
Old Aug 6, 2003 | 06:11 PM
1989redvette
look if its the brushes you will be able to use the manual ***** to get them up.... if it's the bushings they will still not go up right and may "fall" down before catching and then going up...if they fall down if ya hit a bump like railroad tracks or anything like that it's definately the bushings... i myself would try the 4 dollar bushings good luck
:cheers:
Old Aug 6, 2003 | 06:43 PM
FSTRNU's Avatar
FSTRNU
Just replaced both of mine it was a piece of cake. I replaced both the bushings and the gears all in all it cost me 75 shipped
Old Aug 6, 2003 | 07:37 PM
TPFKATK's Avatar
TPFKATK
I agree with 89red. Go ahead and take them apart. If you find the bushings are bad just replace them and you are done. If not, then it's into the motor. Either way you will have it fixed. Did you read on my thread that mine would work if I gave them a start with the ****? Will yours do that?
H
To My right headlight is struggling.....
