does anyone make a tranny flush that i could use in my OD unit?
my cooling lines continue to get plugged, i want to give the system a good cleaning :cheers:
ditto, the lines should not be getting clogged up, may be a bigger problem????
i haven't seen whats plugging them, my tranny runs really hot, when i blow out the lines it run normal.
every now and then it starts again and i have to blow them out. the oil is clean :yesnod:
by hot, i mean you sweat in the car beside the tranny, its like the heat is cranked on hot all the time
