anybody have shift lights or warning lights
Old Aug 4, 2003 | 09:54 PM
fiberglasscoffin's Avatar
fiberglasscoffin
Default anybody have shift lights or warning lights
if you have a shift light or warning light if so where are you putting them and which one any pics would help im looking to mabey put in a shift light or a warning light to use so i no when my nitrous hits something like that
Old Aug 4, 2003 | 11:07 PM
JasonL's Avatar
JasonL
Default Re: anybody have shift lights or warning lights (fiberglasscoffin)
I have a Harlan shift light hidden in the center vent. There is a nice tutorial somewhere on how to install it there... very slick.
The light kicks butt but I have heard the guy making them now takes forever and is not very responsive to emails. So I'm not sure if I can still recommend it.
Old Aug 5, 2003 | 10:30 AM
vvv90's Avatar
vvv90
Default Re: anybody have shift lights or warning lights (JasonL)
:iagree:
I have one myself. It's very stealth and VERY bright. I love it! Was only like $50 or so too. You install it in the "fake" vent right next to the steering wheel. It will take you a couple hours to install, but it's the cleanest install possible. I'll try to get some pics tonight.
http://www.harlan-engineering.com/store/store.html
Here's the install link for the vent:
http://hashmarks.com/ShiftLight/index.html
:cheers:
Old Aug 5, 2003 | 10:37 AM
ski_dwn_it's Avatar
0ski_dwn_it
Former Vendor
Default Re: anybody have shift lights or warning lights (vvv90)
Don't mind the rest of the car. I was putting the final touches on the wide band 02, which you an see the display for in the upper right have corner of the dash.
But that is where I have my Tach and shift light mounted. Works very well there. At night without the cover on it, its almost too bright. :cheers:
Not sure how you would tie that into the nitrous system. ? Can't you tell when it "hits" by the way it feels? :confused: :skep:
[Modified by ski_dwn_it, 10:38 AM 8/5/2003]
Old Aug 5, 2003 | 11:52 AM
rcolling's Avatar
rcolling
Definately get the Harlan light.
I followed the instructions posted for wiring but I didn't want to cut a hole in my car. I mounted it on the drivers A pillar with 3m body molding tape. It is out of sight from outside the car and is very noticeable when racing. It has been in for over a year and no problem with the tape...
Old Aug 5, 2003 | 03:47 PM
fiberglasscoffin
Default Re: anybody have shift lights or warning lights (ski_dwn_it)
o ya!!!!!!!!!!!!!!! but looking for a light i want to see when it gos on and out really i need a dyno guy to set it all up right it hits at 3000 out at 5800 thats what my pills are at but seems like i can go higher car kind of dies out at that last second in the shift but i got a 6000 pill in the msd 6al for the rev limiter?
Old Aug 5, 2003 | 03:57 PM
STL94LT1's Avatar
STL94LT1
Get the Harlan, you won't be disappointed.
Old Aug 5, 2003 | 04:18 PM
fiberglasscoffin
Default Re: anybody have shift lights or warning lights (STL94LT1)
just ordered one from harlen thanx for all the info
Old Aug 5, 2003 | 10:39 PM
larrybsp's Avatar
larrybsp
I use an Autometer shift light mounted on the dash just to the left of my line of sight. I mount it with double sided tape. I have an L-98 and have a 4800
rpm chip in the light. From my Diacom I found shifting when the light comes on I'm actually shifting at 5500 rpm. I have pretty strong motor. Not a bad idea to calibrate the shift light so you shift at the optimum rpm.
Old Aug 6, 2003 | 03:24 PM
NavyVet's Avatar
NavyVet
Jesse, do you still have the tilt? Where did you anchor the mounts for the tach & light? Paul
To anybody have shift lights or warning lights
