Just can't get a brake...
Old Aug 13, 2003 | 01:21 PM
Trog's Avatar
Trog
Default Re: Just can't get a brake... (DVAST8R_88)
Another quick tip from that class on anti-lock brakes I took. The anti-lock system will actually bleed air from the pump system all by itself if you can make it actuate. I've done it not only for that but to get used to how the car & brake pedal feel when it comes on. I know of a local fruit packing shed with a huge gravel parking lot, very flat, smooth & light covering of small pea gravel. Only takes 5 MPH so your not spraying the car with gravel or anything, jam on those brakes & you will feel the pump come on, pedal vibrates a little & the car stops. I do it about 4 or 5 times & the brake pedal is nice & firm after that. Its good for you & good for the car. :steering:
