plugged cat. converter?
Old Aug 5, 2003 | 04:26 PM
Z06_BluByU's Avatar
Z06_BluByU
Default plugged cat. converter?
could a plugged cat converter cause the exhuast manifold to glow.. as well as a code 64 (extream lean mixture - driver side)?
Old Aug 5, 2003 | 04:30 PM
vader86's Avatar
vader86
Default Re: plugged cat. converter? (BluByU)
yes it could cause them to glow
check the fuel pressure though
Old Aug 5, 2003 | 07:01 PM
bac22's Avatar
bac22
Default Re: plugged cat. converter? (vader86)
This is exactly what a lean condition would cause. The extra fuel is burning up in the cat thus eventually melting it. If your manifold is glowing that is pretty much a tell tale sign your cats are clogged.
[Modified by bac22, 7:01 PM 8/5/2003]
Old Aug 6, 2003 | 08:06 AM
Z06_BluByU's Avatar
Z06_BluByU
Default Re: plugged cat. converter? (bac22)
correct me if i'm wrong.. but a lean condition means there is not enough fuel in the exhuast gas.. too much fuel is a rich condition.. The o2 sensor is before the cat converter and its reading rich.. Im just wondering if a plugged converter could set a lean condition code.. (too little fuel)
Old Aug 6, 2003 | 09:43 AM
bac22's Avatar
bac22
Yup, true, I probably shouldn't respond to post when I'm half asleep at the keyboard. :crazy:
It is possible that the O2 sensor is bad. The "circuit" simply reacts to the current "value" of the oxygen sensor (rich or lean) by taking the opposite action. So if the sensor indicates "lean", the circuit will add fuel and vice-versa. So your engine could be running rich dump fuel in the cat, but the O2 sensor could be bad showing a lean condition.
Old Aug 6, 2003 | 11:03 AM
87vette's Avatar
87vette
Happened to me anf freaked me out.
Old Aug 6, 2003 | 01:53 PM
sothpaw2's Avatar
sothpaw2
Could a plugged cat cause the engine to run rough and stall as soon as the engine warms up but not before?
Old Aug 6, 2003 | 06:20 PM
bac22's Avatar
bac22
Default Re: plugged cat. converter? (sothpaw2)
It is possible but it sounds to me that a throttle sensor may be out of whacked, but I'm only guessing on that. Any case look here for a little more info on clogged cats.
http://www.all-catalytic-converters.com/techtip2.html
To plugged cat. converter?
