Posi or not?
Old Aug 6, 2003 | 11:13 AM
V-FORCE's Avatar
V-FORCE
8th Gear
Default Posi or not?
How can I tell if the rearend I have in my garage is a posi or not? Is there such a thing as a one wheel pull Corvette carrier unit? :confused:
Old Aug 6, 2003 | 11:14 AM
scorp508's Avatar
scorp508
C4 = Posi
Old Aug 6, 2003 | 11:20 AM
V-FORCE's Avatar
V-FORCE
8th Gear
Default Re: (scorp508)
thanks :cheers:
Old Aug 6, 2003 | 11:24 AM
C10 JDR's Avatar
C10 JDR
Default Re: Posi or not? (V-FORCE)
Put the car in neutral. CHOCK THE FRONT WHEELS. Jack up the back end. Turn one rear wheel by hand. If the other wheel turns in the same direction its posi. If they turn in opposite directions its not.
Alternatively, don't bother. It's posi. :)
Old Aug 6, 2003 | 11:44 AM
65Z01's Avatar
65Z01
Cruise-In II Veteran
Well, it's a posi but is it fried??
For that you need to lock one side and measure torque to turn other wheel.
Old Aug 6, 2003 | 11:59 AM
C10 JDR's Avatar
C10 JDR
Default Re: Posi or not? (65Z01)
If you can lay down two strips of burnt rubber it is probably OK. :crazy:
Old Aug 6, 2003 | 11:39 PM
PonyH8R's Avatar
PonyH8R
Default Re: Posi or not? (britvette)
This is the quickest way. :yesnod:
To Posi or not?
